How to remove power board
SOURCE: Mag lt782s power board problems
Is it a really fast blink on the power light? If so, you might be looking at the wrong item. The fast blink means that the mainboard has an issue.
Like I've said sever other times on this board, there's an NPN transistor that is usually the culprit. Just yank it and replace it with a Radio Shack NPN and you should be in business (maybe bump it up a touch so that you don't have the same problem again).
SOURCE: mag lcd monitor
probably capacytor problem in the mainboard, take it to the lab it will be cheaper then buying new one
SOURCE: I have a monitor MAG LT782s. Backlight works, but
HI There,
The easiest way to troubleshoot this one is to borrow another monitor that you know is displaying properly on another computer and connect it. If you're still not getting video then it's almost certain your video card has failed.
Regards,
Marcus
SOURCE: Mag monitor lt782s - green light on screen black
This means that the power supply board has a problem. The problem is that the part of the circuit that controls the backlight has failed. This is usually caused by capacitors that have gone bad or transistors that have shorted.
