What is the dc voltage output of a power supply on a sanyo radio awm2100u
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Schematic diagrams to power supplies to many popular brand devices are givne.
SOURCE: Blue DC Power LED comes on but screen does not
OK, so you do have 16 vdc feeding he inverter board, at this point I would replace the inverter board (since the board uses surface mounted parts, it will not be easy to do compnent level repair). Hopefully you do nothave bad lamp assemblies. Also loof for component lebeled with Fxx closed to the white terminal, that is the fuse, see if it is OK on the inverter board.
Try looking here for inverter baord also:
http://www.lcdparts.net
SOURCE: What are the internal DC
You did not give Name brand or model number printed on back of TV,in order to help you I need this Information Thank You.
