This copier has been showing that the fuser has not be set properly, tried fixing but could not manage please advice and also sc 532 on this machine. (Fuser settings error)
SOURCE: Error Code SC553
You are definitely on the right trail, here is what is is. Pressure roller fusing lamp over heat
The detected pressure roller temperature stays at 200°C or more for five seconds. It could be:
• Defective PSU
• Defective BCU
You did the first thing, you will need to try the other two.
1. Replace the fusing unit.
2. Replace the PSU.
3. Replace the BCU.
Remeber the BCU is next to the controller.
SOURCE: Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
SOURCE: Sir, My copier model RICOH MP
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Testimonial: "Sir, Thank you so much for your help, let me try in my copier and revert back once the problem is solved. Thanks Gopalkrishna T N"
SOURCE: my aficio richo 2016 black
This error code is related to a overheat in the Fuser Unit.
Probably you have a faulty thermistor.
I advise you ito call a technician. But you can do this procedure to see if you can work while technician does not arrive.
Press yellow key.
Press 107 on the key pad.
Press red key at least 5 sec.
Press copy SP.
Exit all the way out and turn the machine OFF and ON.
I think did may help you.
See you!
