After a power outage (and returned power) everything in the house works but the Honeywell TH9421C1004. No batteries on the back. I've reset the breaker. Getting pretty hot. Help! Thanks.
SOURCE: Blank Screen on thermostat
check your float switch. On your air hander you have 3/4 white pvc coming out of bottom of unit, where the water drains out. If you have a float and your drain line is plugged it will make your tstat go blank. vacuum the drain line where it comes out of the ground outside.
