I washed pyjamas on 60 degree hot wash with sheets & other items & everything turned pink
You can't. Best option is not to mix colors with white when doing hot wash. Generally colors on own go well with cold wash with the right detergent. When you get new colored clothes like pyjamas rinse separately overnight to get non fast colors out and then put in the general laundry. But always keep whites on separate wash.
SOURCE: not sure whats wrong with my washing machine!
My washer humes like it wants to start but doesn't and i have to constantly push it in an pull it out while its humming, after abot 15 to 20 times of doing this it will eventually start. Help!!!!!!!!!!!!!
SOURCE: washing machine
-the conditioner compartment may be blocked
- the cable with spring that change course of the water may be out,
SOURCE: Conditioner not emptying in Bosch Classixx 1200 Washing Machine
ITS NOT THE DRAW THATS NEEDED CLEANING ITS THE JETS ABOVE IN ROOF OF DISPENSER THESE ARE DIFFICULT TO CLEAN UNLESS YOU USE HOT SOAPY WATER AND A SYRINGE TO FORCE THE BACTERIAL GROWTH BACK DOWN THE PIPES,IF YOU DO THIS KEEP GOING TILL NO MORE BLACK STUFF COMES OUT THEN TRY IT IT SHOULD WORK LEAVE THE DRAWER AJAR WHEN NOT IN USE THIS WILL CUT DOWN THE MILDEW GROWTH.
SOURCE: Wedding band missing in wash!
YES, there is a coin trap, and most likely your ring is in that trap. it is located under the drum on the right side. Here is how it looks.
Now is the bad news: You'll need to remove the front panel to get to it. I can't tell how to do it, have not worked on those newer frigidaires yet, but it's likely going to be fairly hard to do. You will need to remove the control panel and maybe the top to get to the front panel screws. Also be prepared to unfasten the door boot (big rubber seal) and fasten it back when you finish. Additionally, if you disconnect the coin trap from the pump, you might have hard times connecting it back (clamp pliers make that job easier). Before putting back front panel, pour some water intside the tub and check the coint trap connections for leaks. Hope I did not scare you ;)
Testimonial: "Thank you vladimir77! The ring was not in the trap when I got to it. Ran 3 more times until ring appeared! "
SOURCE: my washer leaks water
The problem is due to the rubber boot is been torn that is causing you the leak. You have to check the rubber boot for leaks by removing the clamp assembly that secures the rubber boot to the outer lip of the door opening. Peel off the rubber boot then inspect it for any holes where it may be leaking. The rubber boot in your washer can be accessed only when you remove the front panel. This requires the removal first of the top panel then the console. Also check your inlet hoses on the outside of machine, also check the connections inside the panel in back.
Thank you !!
Maximum load 5.5Kg
Wash Load Examples:
Two examples
of maximum
wash loads for
different types
of fabric.
COTTON
2 Bath Towels
5 Shirts
6 Blouses
1 pair of
Pyjamas
4 items of
Underwear
= 5.5kg
SYNTHETIC
2 Children's
Dresses
4 Shirts
4 Blouses
1 pair of
Pyjamas
4 items of
Underwear
= 3kg
