Pramac E6900 cuts power after a while
SOURCE: Generator runs, but does not generate electricity
Reset / tickled? There are resistors and diodes in the end of the alternators rotor (the bit in the middle that spins) If these look ok visually then change the capacitor which is a barrel shaped object usually with 4 prongs on the end. Without a capacitor the genset will not produce a voltage.
SOURCE: generator will not produce electric power
SUBURA COLEMAN GENERATOR RUNS FINE..IT RAN OUT OF GAS AND MY UNCLE FILLED IT UP AND RESTARTED IT..HOWEVER HE LEFT EVERYTHING PLUGGED..LATER ON, WE NOTICED IT STOPPED SENDING ELECTICAL CURRENT TO THE PLUGS..DOES IT HAVE A FUSE OR DID SOMETHING POSSIBLE BURN OUT...HAVE NOT HAD A CHANCE TO TAKE THE COVER OFF TO SEE
SOURCE: generator starts but gives no 220 volt electric
This is a frequency issue 50 hertz for Europe, 60 hertz in US. It's speed related. Faster RPM for 60 Hz
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: My generator starts but not give 220 volts power
Check the voltage regulator and any fuses or breakers.
SOURCE: portable generator head stopped making power
portable generator head stoped making power engine runs fine sircut brakers are fine
