Should be located at fusebox area under dash on driver's side. Replace the relay. Check the fusebox cover for diagram. Or buy a repair manual from PepBoys, Autoparts, Oreilly Auto. About $20
open the hood, look on the drivers side fenderwell for [main fuse box] black box,plastic cover,remove the top lid,under the top lid will have diagram where the main fuse is located. if you have an owners manual,usually located in the glove box, this will guide you to all fuse panels,under the hood and the dash.but the main fuse is located under the hood in the main fuse box on drivers side fenderwell. clearly marked[main fuse and relays] you may have to turn the plastic bolt on top of the cover[counter clockwise] to remove the plastic cover,look under the lid for exact location of fuse or relay you are seeking. thank you for choosing fixya.com
Should be under the hood in the power distribution box, Sometimes near the battery. Take the top off and the relays are diagrammed on the back side of the lid.
For a 2001 Dodge Caravan: The owner's manual is vague, only stating that all fuses are under the hood in the fuse box, no diagrams. Once you have removed the fusebox cover, the diagrams for what each fuse does is provided under the lid. UNCLEARLY marked is the radio fuse, a 20amp fuse located 2nd row from top to the right of the accessory relay. It is marked: RDO/IP IGN.
The panel or the housing normally lists the names of the items that are controlled by the fuses. If that doesnt work, disconnect the battery terminals and you are good to go
It would appear that the relay is located on the cross rail that runs across the front of the vehicle (in front of the radiator). I found out that it is riveted in place by a single rivet, so in order to replace mine, I will have to remove the rivet and use a self-tapping screw to secure a new one. The fan relay is located in the fuse panel located under the hood beside the battery. It will be marked under the lid. Make sure you check the maxi fuse for the fan also.
