Samsung RS2556 Side by Side Refrigerator Logo
A
Anonymous Posted on Aug 31, 2014
How much does it cost to replace samsung ice maker control board?
Control board ice maker
2 Related Answers
Anonymous
  • 194 Answers
  • Posted on Mar 24, 2011
SOURCE: Hi ! my 3 years old fridge Samsung Rs2630ww
lashing light stating that its too warm .. compressor probably is not running / power is ok or lights would not be on . look for a bad relay . somethes you can here clicking in back.
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Dec 13, 2012
SOURCE: Samsung Refrigirator RS2545SH: Installing my ice maker when I heard several clicking sounds, I realize I forgot to unplug my refrigerator before installing my new ice maker. After plugging back my Ref
First lets check the wiring plug under the top left hinge cover to insure the connection is firm and then check connections at the motherboard. Let me know what happens, Thanks Sea Breeze
Samsung Refrigerator Familiarization
1helpful
Why will the ice not dump? I replaced the ice maker because it was not turning to dump the ice after the ice was frozen. Same problem with new ice maker. Reset button causes the ice tray to turn, dump...
Your ice maker is controlled by the main board. The ice maker has a sensor that tells the board what the mold temperature is. The first step is to make sure your ice maker is turned on. There is an "on/off" setting on your control panel. Look very closely at the glass depicted. Some models show ice cubes in a glass, others have the words ice off. It's difficult to tell without looking close. If your ice is on, a Samsung qualified tech should be called to check connections, and the board.
1helpful
2answers
Ge refridgerator model gh405499
From what I know of ge, ice makers are independent. Mother board has no control over I'm. How old is this fridge. Some of the newer ge are made by Samsung and are control.
1helpful
I have a KitchenAid SxS model # KSRG25FTST01 with an icemaker problem. It stopped making ice, but the water still dispenses. It makes no noise and no water in the ice tray. I never hear it try to fill with...
If the thermostat behind the left side of the fill tray goes bad, the cycle will stop completely. Cost of thermostat is $20.00. Cost of new icemaker with new motor and everything including thermostat is $45.00, brand new, on EBay plus shipping. Cost for new icemaker from repair shop, $153.00 plus tax. Control board circuit panels each side of freezer compartment will go bad also stopping the ice maker cycle. these control boards come in pairs, one for each side of freezer compartment. Cost for new circuit panel control board from repair shop, $215.00. Cost from EBay brand new circuit control board $45.00 plus $8.00 shipping. Easy to install both, icemaker and control board circuit panels. Phillips screw driver and small socket set is all you need for removing and installing these items.
Not making ice
There are several possibilities for this and the dual water control valve is one of the possible problems. Try pouring tap water into ice maker tray if no cubes are present. Allow it to freeze and if the cubes drop then the water control valve part Click Here=> 2188542-1 Then you have a possibility that the ice maker thermostat is at fault item number 27 in photo here=> 627985 Ice Maker Thermostat Sometimes the problem is located inside ice maker and buying new makes it more worth the cost than the cost of replacement parts. This is the Replacement and parts here=> 4317943 Complete Ice Maker
If you need additional help I can be found here or here=> Appliance 911, Thanks Sea Breeze
ICE MAKER WON'T WORK
Most likely the water control valve is the reason that your ice maker will not work. I would like you to fill the ice maker with tap water and if it dumps and does not refill then the water control valve will need replaced. tem # 153540 Water Control Valve If it is the ice maker I will help you find the replacement, Thanks, Sea Breeze
1helpful
Model rs2534ww side-by-side Samsung frig. After power interuption to the home, interior lights work, but digital display is blank and compressor won't run. How do I fix this?
Regarding Samsung refrigerator model rs2534ww/xaa repair: Basic trouble-shooting from Fixya was helpful, but solution required service call from repairman. (Very few repairmen work on Samsung at this time.) We thought problem was the digital controller, but turned-out was ice maker (!). Repairman explained Samsung has wierd control design that is based upon ice maker sensor. Sensor alone cannot be replaced, required entire icer, which he had in the truck. Icer cost $105 retail ($86 online), but controller would have been $161 retail (couldn't find controller online). Hint: if control panel is "dead" except for (only) the upper (horizontal) LED segment of the right-most refrigerator temperature digit, the problem might be your ice-maker. If you find the ice maker online and can install it yourself, you can save at least $130.
Kenmore Coldspot Model 57577791 S/S Ice Maker Problem
Probably the solenoid (electric valve that opens when the ice maker calls for water ) is leaking and has to be replaced (it's a very common problem ) . To be sure the solenoid is the problem , turn off the ice maker by raising the arm up , and check after a few hours if is any water in the ice tray , if yes the solenoid is leaking , if not , the ice maker control board has a problem , and to replaced it will cost you almost as a new ice maker.
Oct 19, 2009 • Freezers
10helpful
Ice maker over fill, water keeps running
If water keeps running to the ice maker all the time even when it doesn't call for water , the water valve for the ice maker is leaking(located in the back of the refrigerator,bottoom right),but if overflow only when it calls for water(no more than 7 seconds) the problem is in the ice maker control board, you can replace it but it will cost almost as a new ice maker.
2helpful
Samsung side by side RS2556BB. Ice maker is not dumping ice out.
you need to remplace your control board
is not suppling power to the ice maker heater element you will find the control boar nex to the wather valve
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
