Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw Logo
Posted on Jul 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the fuel mix ratio for a Craftsman 36cc Chainsaw please
Dwain Pippen
Level 3:
  • Master 377 Answers
  • Posted on Jul 02, 2009
 Dwain Pippen
Master
Level 3:
Answers
377
Questions
0
Helped
345386
Points
1471
Brian Szovati
Level 2:
Sergeant:
  • Expert 344 Answers
  • Posted on Oct 07, 2015
Brian Szovati
Expert
Level 2:
Sergeant:
Answers
344
Questions
0
Helped
103404
Points
899
Yes 40 to 1...BUT make sure your mix is right, better to be more on the oil side than low on it
The oil and gas ratio to mix for a Craftsman 16" 36CC Craftsman chainsaw
The proper fuel oil mixture for your machine is 40 to 1. That is 40 parts gasoline to 1 part oil, or 3.2 oz. of oil per gallon of gas. Be sure to use only 2 cycle oil that is designed to be mixed with gasoline. you can buy premixed at home centers
What is the fuel mix ratio for a husqvarna 55 rancher chain saw ?
33:1.............always mix it on the heavy side and you will never burn your saw up.........go to walfart and get a bottle of "gumout" octane booster and stick it in the gas and it will run better than ever.......
1helpful
2answers
What kind of gas/oil mix does this use
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
How to change fuel lines on craftmans 36cc chainsaw
The best way is to change only one at a time. There are many folks on here that removed everything, then couldn't remember where the lines went. Use original lines, not plastic. Check your work by trying to pump fuel into the primer bulb. Good luck!
1helpful
Sears model 358.356280 chainsaw. Just replaced
Sounds like you need to pull out the spark plug and put some fuel directly into the cylinder to get it fired up.
2helpful
Have craftsman 36cc 16inch bar chainsaw will not idle need to know how to set idle screw
If you did nothing to the carburetor adjustments, are using a fresh (1.5 months or less) fuel mix with the same oil/fuel ratio, are operating at the same elevation, and the air filter is clean, there is a reason your saw is acting up.
The idle sdrew is usually separated fron the other 2 and probaly not fitted with an EPA limiter. HTH
Lou
Nov 01, 2009 • Garden
2helpful
Gas / oil mix for craftsman chainsaw 36cc
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Sep 26, 2009 • Garden
Oil & Gasoline
Hi Thomas, you can find bar oil for the chain at just about any hardware store. Just tell them you need chainsaw bar oil. The oil that mixes with the gasoline is called 2- cycle mix. They will have that also. You can find the 2- cycle mix at a lot of gas stations too but a lot of guys caution not to use the 2 - cycle mix that is made for outboard motors. . Hope that answered your questions.
4helpful
I need to know the gas mixture ratio for a craftsman weedwacker
Hello mcguilmd:
>>All Two Stroke Engines will use a 50 to 1 Ratio using Today's Two Stroke Oils. I once had an Old Chainsaw probably from the 1950s, maybe Earlier 70s that had a sticker on it that said to use a 25 to 1 Fuel/Oil Ratio, but that would have been using Two Stroke Oils of the Time Period the Chainsaw was Manufactured. I was having a Problem with Oil Coming Out of the Muffler and Started Decreasing the Oil in the Gas. I Reduced the Oil Until it was a t a 45:1 Ratio and Decided to be Safe, I would Use a 40:1 Ratio Mix. In that Chainsaw I used 50 to 1 Ratio with no problems. Today's Two Stroke Oils compared to Yesteryears are more Efficient at Lubricating. It is like comparing Today's Synthetic Motor Oil to Motor Oils of Decades ago. All the Equipment I use in Landscaping, anything from a Weed Eater, Leaf Blower, Chainsaw, Hedge Trimmer, use 40 to 1 ratio, and I use all types of makes and models, Stihl, Homelite, Husqvarna, Shindaiwa, and Echo, Sears. I mix up a 5 Gallon Fuel can and use it in all of the Equipment for my Customers and for my Landscaping. I like my Fuel/Oil Ratio a Little Heavy, so I use a 40:1 Ratio. The Following was Copied and Pasted here from and MTD E-mail to me when I Asked for the OEMs Suggested Mixture for this Unit. The mixture, as described by the engine manufacturer, is a 50:1 ratio when using the approved types of 2-cycle engine oils.
50:1 ratio is a mix consisting of 2.5 ounces of 2-cycle oil per 1 gallon of gasoline.
The 2-cycle oil used should be approved and have one or more of the following specification titles: NMMA TC-WII, TC-W3, JASO FB, or JASO FC. NOTE: If unsure of the 2-cycle oil specifications, or the oil is not approved, use a 32:1 fuel to oil ratio. This ratio consists of 4 ounces of oil per one gallon of fuel.
NOTE: Always mix 2-cycle fuel oil and fuel in an approved gasoline safe container prior to filling the engine. Make sure to use a separate gas can for this 2-cycle fuel mixture and label it accordingly. Keep in mind that the fuel capacity of these engines normally is less than a gallon, therefore you will have to use this extra oil mixture for multiple fuel fills. Adding a fuel stabilizer will also help to increase the shelf life of fuel.
>>I Suggest Using a 40:1 Ratio and if Oil Starts Coming Out the Muffler then go to a 50:1 Ratio.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
