Dual flush
SOURCE: jacuzzi toilet bowl goes down very slowly until it
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
SOURCE: Jacuzzi BK37959 White Era
Is there a good flow from the small feeder tube going into the center tube the flapper mounts to? It is possible your flush assembly has mineral deposits,rust,calcium,etc. build up and is not allowing sufficient flow through that tube to rinse the sides of the bowl. You could also Try dumping undiluted C L R (calcium,lime,rust) cleaner into that tube and allowing it to clear the passages. If the passages are blocked you will notice the water flooding back out of that central tube in the tank and may be able to use a small inspection mirror and a piece of baling wire to clear the exit ports around the rim of the bowl. You may also be able to clean the entire flush assembly by removing the water line from the bottom of the tank then removing the flush assembly and soaking it in C L R for a half hour - or, just replace the entire assembly. I hope this helps!!
SOURCE: my jacuzzi toilet doesnt fill with enought water
Hi, W/D here.
Check the water level in the tank. The force to flush waste comes from there. Normally the fill line is cast into the back of the tank, but sometimes it is on the overflow tube. Raise the level if it is low.
Also, make sure that the tubing from the fill valve is connected to the over flow tube (the tall tube).
Best regards, --W/D--
SOURCE: When I flush the toilet,
Attached to the Flushvalve is a rubber stopper commonly called a flapper. If the flapper is worn this would cause the problem. Also sometimes the chain that attaches the flapper to the handle gets caught and the flapper sdoes not seat right. Check this, if it is clear and not obstructed try repalcing the flapper.
SOURCE: jacuzzi espree toilet leaking water
Hi!Maybe the problem of your toilet is in the mechanism inside the tank that's why its always leaking.Kindly check the tanks fittings of your toilet and replace it if necessary.
