SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
SOURCE: Can't find the oil drain plug on Troy Bilt with 5.5 Honda engine
You may want to look under the deck. They sometimes put them there. And if it is a self propelled, you will probably need to remove or loosen the plastic cover that protects the self propelled belt.
You are looking for a nickel sized plug that has a square peg. Use an extension piece for a socket set if you don't have the proper plug removal tool.
Jim
SOURCE: Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
SOURCE: how do you tighten the control cable on a Troy Bilt mower?
Usually near the end of the cable there is a squeeze clamp on the side of the cable. Losen the mounting screw (DO NOT remove it) and slide the cable in the direction that will expose more cable. Tighten the mounting screw and test the control. It is really pretty simple.
Thanks for using FixYa.
Kelly
SOURCE: ENGINE KEEP'S DIEING, PUSH PRIMER BULB AND STARS,
Carburator issue. If you have some mechanical abilty you can pull the carb off else take it to a shop. You probably left gas in it off season. Either the main jet is clogged or the float valve is stuck. Either way, remove the carb, tae off the bottom cover and clean everything out with gum out or a carb cleaner. reassemble and eveything should be fine.
