Starts with key but with remote starts and only runs for less then a second RPM setting??? how to reset?
SOURCE: engine cranks will start fine with key remote will not start it
Did it ever work as far as you Know? Some vehicles have a coded key and if the key is not in the ignition at the time the remote is activated it will not start. Some systems have a key hidden in the system and some have a bypass. It is hard for me to tell you which you have as not being the installer. You may have to contact Avital or go to thier web site for more detailed info.
SOURCE: cranks but engine doesn't start avital remote start
I beleive it is a pink wire for the ignition. If you can locate where it is connected this is your ignition wire. It may have worked loose under the dash.
SOURCE: I have a 1998 Chevy cavalier with Avital 3200
it sounds like its the bypass module. When it doesnt start the car goes into security mode and wont let it start for up to 15 minutes. I would check the bypass module to see if it still has power or has been reset, if its not something you can do, bring it to a local mobile electronics shop and they should be able to take care of it for ya.
SOURCE: I bought a used car
The Camry you purchased may not be equipped with a power trunk. Press and hold the trunk button for appoximately 4 seconds. The trunk should release if the wire is connected and, you have a power trunk.
The Camry (and other toyotas) require a double pulse on the unlock wire. If the double pulse is not programmed the aftermarket unit will mimic the factory keyless entry. One press of the unlock button opens the drivers door. Immediately press the unlock button again to unlock the other doors.
