My device is old, and I am seeking to harvest any music files still of interest to me, however Windows 7 cannot locate the drivers needed online or otherwise.
Microsoft Windows 7 computer with an open USB port and iMesh installed
USB cable compatible with Eclipse MP3 players
Instructions
Plug a USB cable into the Eclipse MP3 player. Plug the other end of the USB cable into an open port on the Windows 7 computer.
Click the "Start" button on the Windows 7 desktop taskbar and click "Computer" in the menu that appears. Click the "Music" item located in the left pane of the "Computer" window that appears. Double-click on the "iMesh" folder. For Windows 7, XP and Vista. Recommended. Download Now.
Click the "Start" button on the Windows 7 taskbar and click "Computer" and then double-click on the "Removable disk" icon that represents the Eclipse MP3 player device. A window will appear displaying the contents of the Eclipse MP3 player storage area.
Right-click on a music file in the "iMesh" directory that has the "mp3" suffix, and click "Copy" in the menu that appears.
5
Right-click on empty space in the "Removable disk" window and click "Paste" to copy the music file to the Eclipse MP3 player device. Repeat for each file you wish to download to the Eclipse MP3 player.
To copy multiple music files at one time to the Eclipse MP3 player, press and hold the "Shift" key on the keyboard. Click once on each file you wish to copy. Right-click on one of the highlighted MP3 music files and click "Copy" in the menu that appears. Right-click on empty space in the Eclipse "Removable disk" window and click "Paste."
Obtaining drivers is a very important aspect in the everyday use of a PC since outdated drivers need to be updated. Drivers can be downloaded from many different sources on the internet and through many third party software programs. Whatever the source, there are a number of times that people download drivers and they realize that what they have obtained are just the raw driver files without any setup. A lot of people get stranded in such cases. The following, is a very simple way of installing these driver files:
Whether under Windows XP, Windows Vista or even Windows 7, do this: 1. Click on the start button and right-click 'My Computer' or 'Computer'. 2. Select manage and wait for the resulting window (if asked whether to continue, continue). 3. Select 'Device Manager' from the left panel. 4. Now, depending on the device you want to install the driver for, or update its driver, right-click the device (you may have to click on the plus sign to reveal hidden devices). select the first option (update driver software) from the drop-down options. 5. In the case of Windows Vista and Windows 7, select browse my computer for driver software and then browse for the folder that contains the files. 6. In the case of Windows XP, select the last option which avoids the internet and click next and select manually locate files and next. Now add the location of the folder that contains the driver files. 7. Click next and Windows will automatically install the driver files for your device. 8. Restart your PC and you are done.
This procedure is not necessary when a setup file is available unless the setup file is corrupted but the driver files are available.
You have to go to devices then click on your sound devices and choose update driver be sure to check the go on the internet to seek drivers as well and be online. If this does not work I use this resource for all my driver issues.
btjunkie.orgis my resource for all ofmy XP drivers I answer this question a lot from folks that need drivers. If youcan I suggest upgrading anyway to Win 7 they are downloaded mostly for youduring the install process which makes it a lot easier these days to fixmachines. Less time in any event go to that site make sure that you have U torrent a torrentfile down-loader program software. Type in the search box once at thebtjunkie site XP drivers you will have thousands of them to download on onedisk insert the disk then go to devices seek the drivers needed to be foundpoint the seek to your drivers disk and hopefully it can be had. I never havean issue with drivers using the software downloaded from there site. I hopethis assists you. It is also for those of you who read this post to keep yourdriver files with your purchase when you bought the computer. If this is notthe case then you will have to hunt them down. John
If your device is listed you will probably be able to get a driver either from within 7 itself or from HP.
If you don't find your device listed, it is very likely there is no driver for this printer to run under Windows 7.
At that point your options are very limited. You can appeal to Microsoft to support the device; you can appeal to HP to write a driver; You can learn to write a driver yourself; you can seek 3rd party support.
It may be time to update your printer or get a second computer that supports the printer for your printing needs.
Release date
2 Jul 09
This download is a driver providing Microsoft® Windows® 7 and
Windows Vista® support for Creative Sound Blaster® Live!® and Audigy®
series of audio devices
File Name
SB24_PCDRV_LB_1_04_0090.exe
This
download is a driver providing Microsoft® Windows® 7 and Windows Vista®
support for Creative Sound Blaster® Live!® and Audigy® series of audio
devices. For more details, read the rest of this web release note.
This download supports the following audio devices only:
Sound Blaster Live! 24-bit
Sound Blaster Audigy Value/SE/LS
Sound Blaster 5.1 VX
Requirements:
Microsoft Windows 7 64-bit, Windows 7 32-bit, Windows Vista 64-bit with Service Pack 1 (SP1) or Windows Vista 32-bit with SP1
Sound Blaster audio devices listed above
Notes:
This driver is only for the Creative Sound Blaster audio device listed above. DO NOT install this driver for other Sound Blaster audio devices.
Please note that all old devices drivers have upto windows xp or 2003 server files becuase now only windows 7 has been launched in the market. So don't worry you can download print server drivers from the site .
If your print server is USB connected , the windows 7 will say found new hardware after that it will ask you update drivers, there you can click on have disk and locate the driver files where you have kept and clickon windows 2000 or xp from here you can select the driver and install it. Defently your print server will work.
Download driver from the Microtek website
extract the files to your drive
locate the setup.exe file where you extracted the files
after the driver is installed reboot the pc
Now for the fun part...
Once PC is fully rebooted plug in Scanner ScanMaker s400 Windows looks for drivers in “windows update” and the “preconfigured driver folder” Windows cannot find a driver. Close “Driver Software Installation” window Open Device Manager Device manager shows yellow bang next to “USB scanner” under “Other Devices” Right click on usb scanner click “update driver software”, Click on “Browse my computer for driver software” Click on “let me pick from list of device drivers on my computer” Click on “Imaging Devices” Click Next Under Manufacture there is no Microtek Click on “Have Disk” Click on Browse Locate ScanWizard 5 V6.63 folder Locate Disk 1 Locate Vista Locate X86 There is a list of INF files Choose first inf file, “Mii_x86_004.inf” Click Open Click OK Now under Manufacture two entries are listed, Microtek and Microtek Driver Team, On the other side there is a list devices s400 is not listed There is an entry for 4800 Scanner Select it and click next An “update Driver Warning” opens select yes Window now shows successful driver update. And the scanner is listed as 4800 scanner Click close Close device manager Open Scan wizard program Scanner works fine. The scanner will not work nativly with windows scanning.
Hello my friend, how are you?
Regarding on your problem, you can do the 1 time search in all your music files regardless of their individual format by using Windows Media Player Software which was pre-installed already in your Xp after you install your OS XP in your computer.
Using Windows Media Player you can group all the music files you have in computer per title, artist, album, genre or even date and names. To do that kindly follow the steps below:
1. Open Windows Media Player located at the program files in your computer. In case you cannot locate it kindly click the START BUTTON located buttom part of your scree. Then click ALL PROGRAMS or PROGRAMS then WINDOWS MEDIA PLAYER. I case WINDOWS MEDIA PLAYER is not their Click ACCESSORIES then goto ENTERTAINMENT then Locate WINDOWS MEDIA PLAYER.
2. After you locate and open wWindows Media Player or WMP kindly click the tab Library then suddenly a consule messagebox pop-up asking "Would you like to search music in your computer?" then kindly click YES Button then let the WMP search and gather all the Music files you have in your computer.
3. Next time yo log in WMP you can goto directly to the Library and select the music you want to play which was sorted automatically by WMP.
Hope this solution will help you solved your problem. if you seek moreassitance just reply to this post.
If you find this solution solved your problem please don't forget to rate this solution.
thank you and Godbless.
Jonas
