I have a 5 year old NEO mp3 player M'Sonic; For a months or so when I try to pick music from the menu it skips the option and switches between video and games (music is in between). Hence I can't listen to any music I have on it. The folder is there; the songs are there but I can't access them via the menu. How this can be fixed? What is the reason? Thanks for the answers!
SOURCE: NaNO 2G Skips music Mp3 Sometimes Stops
I had the same/similar problem. I don't have any copy protected music on my Nano and all of my music is in AAC so I'm still not too sure what was happening. Basically my nano would display the title track then immediately skip to the next track without playing any of them. It kept doing this until it decided to shut itself off automatically. The next time I started it up, it ran fine. I shut it down and let it be for a few hours only to find the next time I started it up, it was doing the same thing. I decided to restore the factory settings through iTunes and had to put all of my music back on my pod. Not cool. I also downloaded an update for the nano and installed it when I restored the settings. So far so good. Hopefully that doesn't happen again. Especially when I'm on the ice or on the hill.
SOURCE: skipping songs
This generally happens when the music is encoded at a low "bitrate", its called clipping. Only solution is to remove the songs from the device. Best of Luck.
SOURCE: my philips gogear (6 GB) MP3 player is really messed up and i need help
Here's what happened: When you first synced your GoGear to Windows Media Player, you may have set up the automatic sync option. When this option is selected, Windows Media Player will add EVERY song, picture, etc from your Library on your computer to the GoGear. Now, every time you sync you device, it adds every new file from your computer into the GoGear automatically. It will even delete songs from your GoGear that were on there before.
Go into Windows Media Player 11 with your GoGear connected to the computer (it will automatically sync and add new files one last time), move the mouse cursor over to the sync tab; a small black arrow will appear under the word "Sync"; click on the small black arrow and a dropdown menu will appear; select "Portable media device" from the dropdown menu, and another dropdown menu will appear; select "Set Up sync"; a window will appear with some information on your device - uncheck the box that says "Sync this device automatically"; click Finish; This will eliminate the problem of Windows always adding songs/files you don't want into your player.
-Tha Mp3 Doctor
SOURCE: It won't let me listen to music
There are a few different possibilities.
1)Your subscription to your digital music service such as Napster, etc has expired. Sorry - unless you renew your subscription, you will not be able to play these songs again.
2) Your songs have DRM-encryption on them. To check and see, right click on an individual song name in Windows Media Player, and click on "License" or "Digital Rights"; if the affected songs have DRM encryption, then get DRM-removal software.
3) Your songs do NOT have DRM-encryption on them. In this instance, follow the procedure for item#2, except click on the link in the License or digital Rights tab that says "acquire license" (make sureyou are connected to the internet first).
-Tha Mp3 Doctor
SOURCE: My mp3 player sometimes skips
I have noticed this happening to my 30 Gig Ipod with some of my music. What I did to fix my problem was replaced the Battery and Restored\Reset and problem went away.
