Why does my Aria Diffuser by Young Living click when I turn it on, but it won't diffuse?
Has worked like a charm for almost three years of regular use. When I filled it and turned it on nothing happened but a clicking noise comes from the unit. Any ideas on what I should try?
Nowadays most of the people use the diffuser for dispersing aroma in room, car, and office premises. As you also looking for the best diffuser for doing the same then I would suggest you to just take a look at Oil Diffusers. This is one of the best websites where you can find all types of diffusers such as car diffuser, jewelry diffuser, room diffusers, and ultrasonic diffuser. I also purchase the ultrasonic diffuser from this website, they provide me the best quality of diffuser at an affordable price. You can also take the best diffuser from here.
Take the Diffuser off and run it if the impeller turns then might be tightening the Diffuser too much, it just needs to not move, doesnt really need a super waterproof seal or anything like that. If it still doesnt turn with the Diffuser off it might have locked up when replacing the Impeller, you can try to turn the impeller manually or remove the cover plate on the back of the moter and turn the shaft manually back there. OOoorr you broke it
I had the same Qustion and found yours so I experimented and after you turn it on push the button and keep it held in until the light turns off!! Mine has the light off now!!!
I am having the same problem. I have no misting at all, only music and colors. I am going to try moving the glass spout so it's opposite the plastic spout--i read that somewhere. I'm also going to start over again with filtered water. I had gotten into the habit of just reflilling and adding more oils. hope this works and helps you too!!
I have a 600mm Chateau range hood with the same problem. To access the globe chamber, you need to first remove the plastic diffuser from the underside of the rangehood. Located at one end of the diffuser will be a small slot approx 10 mm long. Insert a small flat blade screwdriver into this slot and carefully depress the plastic tongue of the diffuser by gently pushing the head of the screwdriver away from the diffuser. As the tongue disengages from the frame you should be able to grasp the edge of the diffuser and pull it away from the frame. Once the diffuser has been removed from the frame, you will be able to change the globe.
To reinstall the diffuser, insert the plain end of the diffuser into the frame of the the rangehood (above the globe) and gently push the clip end back to its flush position.
this is caused sometimes from the igniters not giving enough spark ie. worn out or the gas orfice to the burner has trash in it and needs to be clean out
