Apple iPhone 4 Black Smartphone Logo
Clayton Solski Posted on Aug 31, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to activate iPhone 4 without apple id password
Bought iPhone 4 and tired to reset but requires password of previous owners apple id. I've tried to get a hold of previous owner but unable to, thinking I've bought an expensive iPod. i checked blacklist before buying and its not on list but without erasing it and using my own apple id i won't be able to use it properly
  • Clayton Solski
    Clayton Solski Aug 31, 2014
    i had see a vidoe on youtube where there was a exploite where it was possible to by pass the apple id when activating iphone 4
  • Clayton Solski
    watched and tried some procedure where i had to erase the apple id password and replace it with 8 zeros and then erase the decription icloud account
Cezar Symanski
Level 1:
Habit-Forming:
New Friend:
  • Contributor 10 Answers
  • Posted on Jul 13, 2016
Cezar Symanski
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
10
Questions
0
Helped
2867
Points
69
Generally speaking, you need the Apple ID to reset your iPhone. iPhone needs you to enter the Apple ID to switch off your account and the Find My iPhone service will be turn off. If you are using iTunes to reset your iPhone, you need to enter the Apple ID when your iPhone reboots.
But if you have no Apple ID or passcode, you will have to reset your iPhone without Apple ID. To reset iPhone without Apple ID, you need first put iPhone into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPhone without entering Apple ID easily. Resetting your iPhone with this method will result in wiping all the data in your iPhone.
Step 1: Open iTunes on your computer and connect your iPhone to the computer with a USB cable.
Step 2: After that, turn off you device. Press and hold the Home button for 3 seconds.
Step 3: Put your iPhone into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPhone into DFU mode.
Step 4: When iTunes detects that your iPhone is in recovery mode, you can restore it now.
how to activate iPhone 4 without apple id password - activate-iphone-4-without-apple-id-oxaxc0rwhkhzilrwacqreyis-1-0.jpg Step 5: Click on Restore iPhone. Then you will be notified after the reset and your iPhone will take a restart.
After resetting your iPhone with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPhone, you will get all the data swept from iPhone, and you can restore the files from your iPhone, iTunes backup or iCloud backup. However, you can't backup iPhone to iTunes/iCloud without Apple ID before you reset your iPhone . In this case, you need the third-party iOS data recovery software to help you recover lost data from iPhone after factory reset without Apple ID.
How to Reset iPhone without Apple ID
David Payne
Level 3:
Top Expert:
  • Apple Master 14,162 Answers
  • Posted on Nov 11, 2014
David Payne
Apple Master
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2994935
Points
455836
ZFix
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 127 Answers
  • Posted on Aug 31, 2014
ZFix
Expert
Level 2:
Mentor:
Answers
127
Questions
0
Helped
23904
Points
316
You can't activate it without the password from the previous owner. This is a new level of security from Apple. You need password or previous owner must to erase it from his account.
5 Related Answers
Anonymous
  • Posted on Feb 03, 2009
SOURCE: white apple in middle of black screen of iphone3g
Looks like your iPhone won't boot, It happens sometimes if your phone is jailbroken and you have installed another non-standard language interface, i install Hebrew on my phones, If i then erase all settings it will fail to boot, like yours...
I suggest you restore the phone and re-jailbreak
since you have erased all settings i presume you have no personal data on it, if you do have contacts/calendar/SMS items, try to backup via iTunes before you restore, even when only the apple is showing, sometimes you can connect to the phone via iTunes/WinSCP
Matthew Boulden
  • 440 Answers
  • Posted on Jul 17, 2009
SOURCE: iphone 8G forgotten password to unlock phone
The only way to bypass it is to put it into recovery mode. You can do this by turning it off and then holding the home button down then plugging it into the computer with itunes. The one you sync with. The phone will be in recovery mode, start iTunes and then you will be prompted to restore your phone. If you need further assistance, please ask.
Anonymous
  • 5 Answers
  • Posted on Nov 30, 2009
SOURCE: iphone 3g will not ring only vibrate
try going into the settings on your iphone. Then go to sounds. At the top of that page, it says vibrate and under it it says ring. Make sure that the slider next to the ring tap is on not off. I hope this helps!
Anonymous
  • Posted on Dec 12, 2009
SOURCE: Can't recognize caller's name when including country code
Easy. (hope not too late :))
1. Press green phone button (as making call, list of recent calls appears).
2. press "menu", go into "options", then go to "smart dialing".
3. Choose correct "country code" and "national number lenght".
4. save.
Good luck! (Pearl is the best phone ever, you just have to use some brains to make it usefull :) )
Anonymous
  • 10515 Answers
  • Posted on May 28, 2010
SOURCE: My iphone 3GS is stuck
This is not a good sign and one of the most common causes with this device. I could tell you a series of troubleshoot.If that would not work, device needs to be send for repair.
Have you tried a hard reset? Hold the Home and Sleep buttons together for 10-15 seconds, until you see the Apple logo come up on the screen. You may need to do this while the phone is plugged into it's charger or a computer, so that it has power.
Usually If it's stuck at that screen, and holding the buttons together for 10-15 seconds didn't help, then there's a hardware issue, and it will need to be replaced.
However, try few more steps
1. Connect to iTunes via USB. Do not disconnect for rest of these steps. iTunes may appear frozen or stuck with spinning beachball....this is okay, do not Force Quit iTunes. I tried a few times w/o it being connected to iTunes and it doesn't work.
2. Once connected, hold Home + Power until screen blinks then Apple logo comes back up.
3. Wait until Apple logo dims slightly (~5 minutes or less). Do NOT reboot until the apple logo dims.
4. Hold Home + Power again until it reboots and Apple logo comes back up.
5. After 2 min or so, the phone may vibrate once or twice. Continue waiting for the full 5 min until Apple logo dims slightly. iTunes at this stage MAY recognize the phone...do not sync or do anything in iTunes.
6. Hold Home + Power for the 3rd time until it reboots. Phone may vibrate again after 2 minutes or so. Eventually you'll break into your Home screen.
Or
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Disconnect you phone from your pc leaving the wire connected to your phone not your pc.
open itunes
hold sleep wake button + home button until your screen goes blank...
let go of sleep wake button and continue to hold home while plugging back into pc... should take about 15-30sec and itunes will see your phone in restore mode
IF THIS NOT WORKING
Try rebooting you phone by plugging it into the charger & turn wall socket on
If that also does not work then you need to take it the apple store.. They will replace it or service it.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
How do I unlock my ipad activation lock without i-tunes. I forgot my password and apple I'd.
If you bought a second-hand iPhone/iPad stuck on the activation lock screen and don't know the previously used Apple ID and password, iMyFone iBypasser can help you activate iPhone/iPad without Apple ID. This excellent tool came out in 2020 and has helped many users who reset their own iPads without logging out the previously used Apple ID.
3answers
How do you unlock the Activation Lock on an ipad when you don't know required Apple id or Password
Your apple ID is normally your email and use the FORGOT PASSWORD line they will send a reset to your backup number or email address
2answers
I have a ipad ios 9.3.5 and its lock me on activation icloud pls help me to skip icloud activation lock
Hey! sorry but you will need to enter that appleID password to reactive the iPad. If you still have the original receipt you can call apple and have them start the recovery process.
I have iPhone 6&6s..form previous owners..how do I start when it asks for ID's and they can't remember
But if you have no Apple ID or passcode, you will have to reset your iPhone without Apple ID. To do this you need first put iPhone into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPhone without entering Apple ID easily. Resetting your iPhone with this method will result in wiping all the data in your iPhone.
http://www.leawo.org/tutorial/how-to-reset-iphone-without-apple-id.html
Dec 21, 2016 • Cell Phones
Used iphone 4 needs an apple id and password for the old owner
The only possibility is contacting the previous owner. Without his id and password there is nothing you can do with the iphone. It's the "find my iphone" option under icloud in the preferences app. There are A LOT of apple products (iphones, ipads etc) which are locked to an icloud account and people try to sell them. DO NOT BUY such phones/ipads!! They're perfectly useless!
Iphone asking to be activated no orig sim
It sounds like the handset is iCloud locked (find my iPhone hasn't been turned off). This happens too many second hand phones, the previous owner isn't aware of this or u have bought a stolen phone?
If you know the previous owner they would know the apple ID and ID password to activate it, after that you would have to do a reset the phone.
Good luck
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
