Checked horn fuses, they look ok...
When you push on the horn pad you should hear a click, if you do then the system is working from the horn pad to the relay as the relay is what is clicking. then you just have to check at the horn connector to see if you have power, if you do then the horn is no good. if you don`t then check the wire from the horn back to the relay for a problem.
SOURCE: Horn doesnt work
its probably not the horn itself but it might be the horn button on the steering wheel, it probably the clock spring messing up , if it is than be very careful with the airbag when you pull the steering wheel off , just disconnect the battery and wait 5 to 10 minutes before disassembling the steering wheel
SOURCE: horn doesnt work but fuses and relay are good
In most cases this problem is caused by the rotating ribbon circuit contact under the steering wheel having a broken filament, the part is known as a clock spring contact, u will need to properly disarm the airbag and remove the steering wheel to access the part. WARNING: Failure to follow factory Airbag disarming protocol can result in an unexpected Airbag deployment and possible serious personnel injury or death.
SOURCE: horn not working. fuse and relay ok. how can the
Check your ground wiper on the steering column.
SOURCE: Nissan sentra 2001 Horn doesn't horn. I checked
the ground on the back of the steering wheel is probly bent
SOURCE: windows and sunroor inoperable wont go up or down checked fuses
check sunroof motor, check if power gets to it when operating switch, if not, the switch is defective, if you get power, the motor is defective
