SOURCE: i have lost the battery cover off the baby
I contacted the maker of the doll zapf and they told me to contact the dolls hospital, so i got in touch with them.
SOURCE: baby swing......graco doesn't swing
We`ve recently bought a 6 speed swing second hand and had exactly the same problem ie it only worked when the swing was empty. We found that if you give the swing a nudge before switching on the motor this sometimes works as the motor only has to keep the swing moving.
If this doesn`t work, strip the motor down and check the contacts. A poor contact will mean that you get less power from the motor. Be careful not to break the connectors on the motor as you take it off as they are fragile. If any contacts appear weak, then they should be carefully soldered to make a strong contact.
Then carefully reassemble the motor on the swing and give it a push to get it going before switching on the motor.
Hope this helps someone reading this.
Ian and Ellie.
SOURCE: The battery cover slipped off and got lost. Can I
This seller can help you - http://myworld.ebay.com/elmira.lv
SOURCE: assembling baby swing
I have a baby swing in pieces. Could you show me a picture of how it is put together please
SOURCE: i purchased a baby einstein
Did you find the instructions yet? I found them on Graco's website for my Baby Einstein swing:
http://download.gracobaby.com/ProductInstructionManuals/ISPS037AB.pdf
