I have numerous songs on my iphone and PC but when downloaded on VIBE the message is (on PC) that folders are not set up to play. How do I sync onto VIBE to enable me to add them to my song list and listen to them?
SOURCE: "Playlist On The Go" on a Philips 4 GB SA6045 mp3 player.
I just figured out how you clear the songs from the "playlist to go". go to playlist to go, then when it shows the songs you have added press the up button and you will see the words "clear playlist to go", press the forward button and it will ask you to clear it or cancel, select clear and it will tell you it's cleared.
SOURCE: File format not supported
use the media converter from philips this: Media Converter for Philips
SOURCE: my mp3 player wont play anything
hmmm, that means that you may have synched some songs that are not fully compatible with your go-gear. although it is still mp3, it may have some "codecs" issues with it. and thus making your go gear crazy. what you can do is delete all the songs you have there, and make a fresh start from scratch, that way, you'll know.
SOURCE: Phillips GoGear 4Gb - Can't sync songs onto player...
This is only a makeshift solution.
I use a philips gogear sa52xx and found out, that deleting the drivers, then reconnecting the Player and pressing F5 in the explorer allows me to normally access the philips gogear sa52xx for about 30 seconds. After that, out of nowhere the drivers will sever and the Code 10 error appears. So, another disconnect - deinstall of the driver - reconnect - F5 in the explorer until the Player appears and then sync. The proplem is, that this works best (maybe only) with mp3 files...
So convert your music files into mp3 first, than do above steps for drag 'n' drop.
Usually, you need to do the whole procedure 2 times for a CD, sometimes 3.
SOURCE: Philips GoGear SA3245 - Playlists Not Showing Up on Player
Have solved this problem on GoGear syncing with WMP 11 by going to options on the device itself, then go to the "settings" option, scroll down to "PC Connection Preferences", from here you will select the check box saying "MTP" then back out of options and connect your device and go back to your WMP 11 and drag your playlists to the syncing area and resync your device. You should then be able to see your playlists under the playlist option in music along with the "playlist on the go" playlist.
Hope this will help!
- Jared
Determan Technology LLC
