WED6200SW1
SOURCE: replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
SOURCE: whirlpool leb6000pq1 not heating
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer' circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: Maytag Performa dryer blowing heating elements
Hi and welcome to FixYa. You should check the dryer vent ducting inside and outside the dryer for restrictions / clogs to include the vent flapper. Poor air flow through the dryer will cause hot spots. If the blower is slipping on the motor shaft this too can cause poor air flow.
When you change the heating element AGAIN... break out the crevice tool and de-lint everything you can access. Also pull out the lint filter and wash it with white vinegar and water then soap and water. Fabric softener sheets material builds up on lint filters. It looks clean but air will not pass through the lint filter.
I think once you get it all ceaned up including all of the ducting to and through the outside wall it will work normally with no problems. I do not think at this time that you have an electrical problem with the outlet supply.
There is one more thing to check and that is the high limit thermostat. It could be STUCK. It will most likely be labeled L180 or L190. That thermostat is suposed to open at either 180 deg or 190 Deg depending on which one is installed. If it does not open then you will keep cooking your elements. We test them with a match and an Ohm Meter. Match under the removed thermostat CLICK. Thermostat opens (no resistance)
Wish ya the best.
Thanks for using FixYa.
Kelly
If anything in the future crops up with this same issue.
SOURCE: Whirlpool Cabrio model WED6200SW1 clothes dryer
There are two thermistors (thermal sensors) in this dryer; one is the outlet thermistor located on the blower housing and the other is the inlet thermistor located on the heating element housing as an integral part of the high-limit thermostat.
These thermistors are negative coefficient type and monitors the dryer temperature on their locations according to their resistance which varies inversely with the temperature. The resistance drops as the temperature rises and rises as temperature drops.
One or both of the thermistors has an open connection or high resistance which makes the electronic control board thinks that the dryer temperature is low no matter how high it is. The electronic control board then doesn't cycle the heater relay and continue to turn on the heating element. The dryer temperature continues to rise and this blows the thermal fuse.
Make sure the thermistors are connected snugly. Remember that loose or open connection means high (infinite) resistance which makes the electronic control thinks of low dryer temperature. Measure the resistance of each thermistor then refer to the tables below. Replace the thermistor if the resistance reading doesn't comply with the table.
Let
us know if you need further advice. Please accept
the solution should you find it helpful and informative. Accepting the
solution will not stop you from communicating with the expert. You can
still communicate with the expert should you need further advice
regarding the issue stated herein.
