SOURCE: my price pfister tub valve leaks
there is an o-ring inside the valve that seals. It has failed. They should sell a rebuild kit where you bought it, or dis-assemble, and take the failed oring in to have it matched to a new one.
SOURCE: Price Pfister Shower--No water to shower
Does the tub spout water flow stop when the shower knob is pulled?
Was the systems pipping flushed before the shower head was installed?
It may be clogged, remove the shower head and then attempt to operate. If it is clogged you will see debris trapped in the screen at its connection point. The shower head can be disassembled - cleaned - reassembled
Is the shower head an adjustable type, that may be in the off position?
Good luck
Aduz
SOURCE: PRICE PFISTER TREVISO SINGLE HANDLE SHOWER - WATER NOT HOT ENOUGH
Check the manual that came with the unit and it should tell you how to adjust the max temp inside the fixture. Hope this helps!
SOURCE: swaping Pfister Shower leaver handle
it must be the same model number,most models come in different colors and styles.
SOURCE: Is there a pdf manual
Here are all pdf's you will need...
http://www.pricepfister.com/product_catalog/document_search_results.aspx?doctype=12
heatman101
