After I replaced the fuser unit I got this message ,I checked the printer well **** I haven't get the reason of message , Please advise
SOURCE: Paper Jam Message
Thanks for the solution. I have a oki B4300, same problem.
I opened top, removed toner/drum. On your left, in front, there is metal roller held by springs. Plastic strip is just in front of this. Two square windows under plastic strip should look dark.
In my case, the Left "window "was white. This was a very small piece of paper which also extended under a small, moveable magnetic switch to the far left. I removed this paper by grabbing it (next to the switch) with a pair of surgical forceps, gently twisting it until it could be pulled out. No need to remove any parts. It now is fixed!
Thanks again.
SOURCE: I´ve got a message on my oki C5510 mfp
Check the toners are not empty. The printer only estimates how much it thinks should be left, there is a possibilty one is empty. this is best done by removing each toner in turn and checking that the hopper in the drum is full to level with the sponge surrounding it. Next check are the toner sensors. These are small and located to the right of each toner cartridge in the wall of the printer, one could be dirty creating the error and not allowing the printer to start up completely, causing the scanner connection to fail and giving you "Failed to get printer information". On this model the scanner and printer are essentially separate units joined by a USB cable.
