Sylvania 6427TE 27" TV Logo
w
wanda davis Posted on Aug 30, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What to do when screen show now scanning - Sylvania 6427TE 27" TV
Level 3:
Top Expert:
  • Sylvania Master 76,851 Answers
  • Posted on Aug 30, 2014
Sylvania Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14991662
Points
237762
Check the horizontal & vertical scanning section circuit. What else to do?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Stop scan fv300.
The instructions for FV300 are a little incomplete. When scanning the Z symbol is already showing. You must press the menu button 6 times until the Z shows up again. In the lower left of the screen you'll see ON. Now push the + or - key and you'll see OFF in the lower left of the screen. If you delay too long scanning will start again and then you must repeat the above steps.
My lowrance sturcture scan shows the bottom and depth but doesn't show structure
don't quite understand what your saying far as the question..when you click the page button on your unit does it show structure scan on the page and if so you go into structure scan and its not showing structure on the screen ?? maybe you need to (fine tune ) your unit or check your transducer to see if its working
How to scan using hp j4580. Booklet only tells how to fax!!!!
  1. Open HP Solution Center with one of the following methods:
    • Click the Windows icon c01319360.gif , click All Programs , click the HP folder, and then click HP Solution Center.
    • Double-click the HP Solution Center icon on your desktop.
  2. If you have more than one HP device installed, click the tab or icon for the product that you are using to scan.
  3. Use one of the following methods to start the scan:
    • For photos or artwork : Click the on-screen Scan Picture "button" in HP Solution Center.
    • For a text document with or without graphics : Click the on-screen Scan Document "button" in HP Solution Center.
    A screen displays to prompt for scan settings. If a settings screen does not display before the scan starts, a preference was set to bypass the prompt. To adjust settings, follow these steps to turn the prompt back on:
    1. Cancel the scan, return to the home screen of HP Solution Center, and then click the Settings option.
    2. For the HP Solution Center "button" that you are using ("Scan Picture" or "Scan Document"), set the option to prompt for settings each time you scan, and then click OK .
    3. Start the scan again.
  4. Read through the various options for the scan settings. Make selections for at least the following items:
    • Scan to: Select your scan destination from the drop-down list.
    • File Type: Select the file type from the drop-down list.
    • ...Save Options...: (available only for certain "Scan to" destinations): For example, if you are saving to a file, click this option to select your Save Location .
    • Show preview...: Select this check box if you want to see a preview before the actual scan.
    Important : HP Solution Center software versions vary, depending on the age of your product, and whether you installed updated software after the initial setup. For specific instructions on all the settings the software offers, click the Help button on the home screen or settings screens in HP Solution Center.
  5. Click Scan . The preview screen might display, if you selected an option to show a preview. Use the options on the preview screen to make any desired adjustments before you complete the scan.
After the scan completes, it goes to the destination that you specified in the settings.
How do i scan to my computer
As long as the printer/scanner is hooked up to the computer, you should be able to put the document on the glass face down, close the lid and press the scan button. The HP screen will pop up on the computer screen, don't mess with that, just let the document scan (it should show you the progress) and once it's done, it will ask you if you want to scan something else or be done. If your done, click done and then it will open up the HP window and show you what you scanned. To retrieve the scan, I always go to start, my documents, my scans and look for the current month and year, open that folder and then you have access to the document you just scanned. Hope this helps.
I cannot scan to my computer using my scanner
After loading the auto feeder, Scan Menu asks me to select computer. I press OK. The banner reads (my name)+ macbook pro. I press OK. Screen reads Tiff To Preview and then Press START SCAN to begin. I press OK. Screen reads date and time and Original loaded. I press START SCAN. Screen reads Starting Scan...., but reverts to Original loaded. I have also tried scanning using the computer (MAC). At times it will run one page of four and then a screen pops up reading..Unknown Error. The hp will print and is showing connected. Thanks
1helpful
Cannon MP530 scanner won't scan document it shows error code
hello ! reinstall the machine fax and scanner program cd's may be the installation was not completed or is the machine having issues .
HP Photosmart 3310 All-in-One Scanner stopped working
No scan options
Refer to device documentation to troubleshoot.
4helpful
Printer won't scan a picture
I had the same problem, but I was able to scan my first photo today. If you are using Windows Vista and have Windows Photo Gallery on your system, you should be able to scan your photo/documents. Open Windows Photo Gallery 1. Click File, and then click Import from Camera or Scanner.
2. In the Import Pictures and Videos window, click the scanner that you want to use, and then click Import.
The rest should be self explanatory. Good luck!
5helpful
Stuck on P-Scan
Most DVD players has a P-Scan on/off button in the remote control. On the other hand, Memorex in some of its models have the P Scan switch at the rear of the unit. It is a slide switch.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
