Settings/Mail, Contacts, Calendars then tap the account you're having trouble with.
Assuming you're using an IMAP account, tap the account user ID on the first line. Scroll to the bottom and tap Advanced.
Tap Deleted Mailbox. In the ON THE SERVER section, tap Trash (making the Trash mailbox on the server your "Trash" location). Back up to Advanced and make sure MOVE DISCARDED MESSAGES INTO: is set to Deleted Mailbox.
You may want to do the same thing for your Sent Mailbox (using Sent on the server for sent messages - so they're retrievable from your desktop).
This fix may result in all the old deleted messages on the iPad being moved to the server and then showing up again in your deleted messages on your desktop. The Mail app will eventually delete them as it does any deleted messages according to its settings.
SOURCE: I have just got an
You will need to setup a Exchange mail account on your ipad to receive all the mail and calendar items that you see on your Outlook mail and calendar.
Here is how to add an exchange account:
. From the Home Screen, tap Settings
2. Scroll down and tap Mail, Contacts, Calendars
3. Select Add Account > Microsoft Exchange.
4. Now type into the following information:
* Email: your email address
* Username: your-Exchange-User-name
* Password: your-mail-password
* Description: It's Optional
* Server: ****.com
For your username, and server names, you will need to contact your company's IT department for the credentials. But your username is the one your IT dept. gives you for email access and password. exchange server name is the server address to access your mail.
SOURCE: I cannot access old Outlook (2007) emails on my
1)Press settings icon (the one with the cogs)
2) than scroll to Mail, Contacts, Calendar and press it.
3) Find your email account you want to modify and click it
4) find the section on the bottom that says "Mail Days to Sync and press the button
5) Now, you have limited options there, but you can pull email from 1,3 days or 1,2 weeks, 1 month or No Limit. If you click no limit it will pull your entire inbox. So, I might be careful in saying it will drain battery power. And or take room on your ipad away. So, if you have old emails with big attachments, be weary. Plus, depending if you are pulling all this mail over 3G you should take note of your data limits.
Hope that helps.
SOURCE: good day, i can't see my emails in my email
To check for account tap settings and tap mail,contacts.calendars.Under accounts see if any listed.If account is not listed tap add account and choose service then sign in.If listed choose account and check settings for correct address and password.Click done when finished
Open the Settings, then visit the Mail, Contacts, Calendars section and you should be able to remove any email address you have added to the iPad.
SOURCE: how can i view the trash folder on ipad 1?
There is no so-called trash folder on iPad 1. You can take a look at this article that maybe helpful to you: http://www.ipaddatarecovery.org/ Best wishes!
