You can use Android data manager tool to help you transfer photos from LG G2 smart phone to computer easily. After connecting it to computer via usb cable, the tool will scan out all photos on LG G2, then you can choose photos you want to transfer to pc. LG File Transfer How to Copy Data between LG and Computer
You can do this with LG PC Suite
http://www.lg.com/ca_en/support/pc-suite
or, if you connect your mobile to the PC on Mass storage mode or Media sync (MTP) mode. You can found our photos and videos in folder named DCIM.
SOURCE: LG PHONE PICTURES INTO COMPUTER
you need to go to your menu bar
go over to settings and tools
go down to memory click on phone memory
down to my pictures
click options
move
mark all
and click done
and they should all move to your memory card.
hope it helps!!
((same for Videos))
If you bought the SD card from Verizon then you should have another card where you insert the card into the regular sized and it works that way. Good luck!!
SOURCE: transferring photos from LG Vu to my computer
i have a usb cord and a memory card for my phone but i dont know how to put the pictures on my computer and i cant send pictures.
SOURCE: How do I use bluetooth wireless adaptor to
connect your bluetooth adaptor to your computer and let the computer install the necessary drivers for it. when it is successfully installed, you will then be able to use the bluetooth adaptor to browse through a bluetooth network your LG phone when you set your phone's bluetooth visibility to ON
SOURCE: Hi I can not transfer my photos from LG Renoir KC910
Hi,i think you need a detailed step by step guide to assist you with the task before you i.e transferring photos from you phone to your laptop.
Below is a detailed solution to your problem;
STEP 1.
Most mobile phones nowadays come standard with a USB data transfer cable and bundled software utility. Check the box that your mobile phone came with for the cable and CD-Rom. If not provided with the software, it may be available as a free download from the manufacturer’s website.
STEP 2.
Once you have located your software CD, check the system requirements necessary to run the software such as hardware specifications, operating systems supported etc. Install the software following on-screen instructions, but do not plug in the USB data cable or phone in just yet, unless the software requests you to do so during the installation process.
STEP 3.
Once the installation is complete, the software would usually require a reboot of the PC before plugging in the mobile phone for the first time. Then connect your mobile phone to the data, and the cable to the USB port of your PC. Several phones may display a message on the mobile display that the phone is now connected to the PC, but if not don’t worry just yet!
STEP 4.
Once connected, start up your mobile phone’s software, and browse through the interface. Most manufacturers offer some form of phone browser where you can browse through the content on your phone, copying files onto, or taking files off the mobile. The software utility may also offer a separate tool for transferring photos and video shot with your mobile, if this is the case use the utility!
STEP 5
.Use the software’s browser or photo utility to transfer your photographs to your PC. Some software tools provide image editing tools as well that will enable cropping, rotation, and sharpening of images once transferred to you PC. Don’t be afraid of referring to the software’s help file incase you get stuck.
The above guide will be of great help to you,as a note of warning;Remember never to unplug or disconnect the data cable from the phone during a data transfer or you could end up damaging your phone or loosing all your data.
Thanks and take care
