Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Logo
A
Anonymous Posted on Aug 29, 2014
<!-- from fixya rte -->Whrere would i buy parts for my weed eater - Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger
Arthur
Level 3:
Master:
  • Master 718 Answers
  • Posted on Sep 03, 2014
Arthur
Master
Level 3:
Master:
Answers
718
Questions
0
Helped
187142
Points
1198
Ebay is a great place to purchase weed eater parts.
5 Related Answers
#1 Taper
Jim Parker
  • 1041 Answers
  • Posted on Jun 16, 2009
SOURCE: Poulan Weed Eater Trim Line Constantly Jams
Sounds as if the line is wound on the spool the wrong way, causing it to want to always feed string.
Jim
#1 Taper
Jim Parker
  • 1041 Answers
  • Posted on Jun 28, 2009
SOURCE: weed eater starts, runs 5 min. then cuts off
The gas cap may be clogged.
The next time you run the trimmer and it starts to die, loosen the gas cap. If it starts running again, then you know that it's a clogged gas cap.
You may also check the air breather, it may be dirty as well.
Just let me know if you need further assistance.
Jim
Anonymous
  • 3600 Answers
  • Posted on Aug 13, 2009
SOURCE: WEED EATER STRING
you have the string in backwards, or the gear is not ingauged.
Anonymous
  • 279 Answers
  • Posted on Aug 28, 2009
SOURCE: weed eater won't start already Tried new plug
Did you check to see if the plug fires? If it shows a spark, check the air filter. Did you prime the carb? Does the fuel mixture mive smoothly through the plunger? If all that is okay, go through the carb. You might take a SMALL amount of fuel mix and put it into the spark plug hole, try to fire it. If it fires, probably your problem is the carb or fuel delivery to the carb....Good luck...Lee
Anonymous
  • 64 Answers
  • Posted on May 04, 2010
SOURCE: Having a problem starting my Shindaiwa T22 Weed Eater.
take the spark plug out and pull the engine over with the spark plug in the wire and ground the plug to the trimmer and see if it sparks. if not flip the switch the other way and see if it sparks then you shall know.
On a featherlite weedeater what's the small green thing that's stuck in the gas cap vent on the inside of cap called???
It is either the tether or the non-return that lets air in, but doesn't let gas out. Most parts are obsolete.
Trimmer parts list - Weedeater Featherlite
http://www.weedeaterfeatherlite.com > parts
Weedeater Parts · 1. Handle · 2. Isolator-Handle · 3. Nut · 4. Screw · 5. Shroud · 6. Shield-Heat · 7. Screw · 8. Screw
Weed Eater Featherlite Type 1 Gas Trimmer Parts
https://www.ereplacementparts.com > weed-eater-feathe...
Need to fix your Featherlite Type 1 Gas Trimmer? Use our part lists, interactive diagrams, accessories and expert repair advice to make your repairs easy.
Featherlite (Type 1) Weed Eater Trimmer - PartSelect
https://www.partselect.com > MFGModelNumber
Get Parts and Repair Help for FEATHERLITE Weed Eater Trimmer - Gas Trimmer. View parts like Engine Fuel Filter and Fuel Line.
1helpful
Where can I buy spear parts for a weed eater WT250 CLS serial number 09217N400103 manufactured date 2009
hi mark.i have a had a look around the internet and all i can find is..its all saying ebay.
you could try going to this link and see if you can find anything but you will see a lot are saying ebay.
buy spear parts for weed eater WT 250 CLS serial number 09217N400103...
Nov 06, 2017 • Garden
I need a trigger for a craftsman weed eater
Go to http://www.searspartsdirect.com/
Select model number and her your model to look-up the part number and you can then order the part from them or some other dealer using that part number.
Can I use 4 stroke oil in a ryobi cs 26 weed eater?
only if you want to buy a new weed eater.
Jun 20, 2013 • Garden
1helpful
Ss30 ryobi weed eater fuel ratio
I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
How do you fix a broken gas line to gas tank that was previously glued but does not hold and leaks gas to a Poulan GE21 weedeater?
Buy a new gas tank! Are you serious! Or buy a new weed eater, if you can't live without this one, those models are cheap, don't waste your time.
1helpful
Need to add new string to a weed eater xt 12
    For manual go to;
    http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
    Preparation Instructions
  1. Press the lock and rotate the spool counter-clockwise.
  2. Remove the locking ring if your weed eater has one.
  3. Take off the automatic feed button.
  4. Wipe away any debris.
  5. Push down on the spool to release the locking tabs.
  6. Remove the spool from the chamber. Restringing the Weed Eater
  7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
  8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
  9. Secure each of the lines into its own upper and lower deck grove settings.
  10. Install the spool back into its chamber.
  11. Pass the lines into the left and right holes and snap the spool into place.
  12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
  13. Reinstall the locking ring if necessary.
Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
Jun 01, 2009 • Garden
2answers
Where can I find a manual for the PE550 weed eater
You can download one online at... http://www.poulanpro.com/poulanpro/indexAction.do?id=default Scroll down the right side to 'Download Manuals'...then enter your model #.. you can then download the owners manual or parts manual. Dwain
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
