SOURCE: Bialetti will not make coffee
I would check the grind size you are using. Maybe it is ground too thin and the pressure cannot push through.
Also, remove screen and washer and make sure passage to the top is clear.
Shop Bialetti's Soon on:
www.CeriniCoffee.com
SOURCE: Bialetti sputtering after gasket replaced
Flame is too high and the top is not screwed tightly enough to the bottom. Also make sure there is enough fine ground coffee in the funnel.
SOURCE: How much coffee?
Fill it as full as you can with fine ground coffee. I cut the resulting brew with an equal amount of boiling water. Called an "Americano" in Italy.
SOURCE: Hello, I have a bialetti mokona,
I do not have this model, but on my old one there was a metal cap that would fit over the coffee receptacle (it diverted the steam from the coffee-making process to the wand to steam milk). Sometimes I would forget to remove that cap before I made coffee again.
Do you have anything like that on this machine?
SOURCE: I was looking for instructions for a Bialetti
Here is the owner's manual. Also, by filling the filter with espresso grounds and using water, you are making espresso. It only becomes cappuccino by adding milk.
http://www.google.com/url?sa=t&source=web&cd=5&ved=0CEcQFjAE&url=http%3A%2F%2Ffantes.com%2Fmanuals%2Fmukka_express_manual.pdf&rct=j&q=Bialetti%20%22Mukka%20Express%22%20owners%20manual&ei=JdWATp7uLcu4tge7prWNAQ&usg=AFQjCNEIi9J9flq7TmgLWUYOiLF4KatH3g&sig2=UqfzIzEfVCpfZv60t1wClg
