Universal MX-900 Remote Control Logo
A
Anonymous Posted on Aug 29, 2014
When turning on tv does not complete cycle on sreen
I have a 42 inch flat screen tv set only the blue and red led turns on nothing else the sreen stayes black my little girl played withremote cotroll from then it stoped working i think its on stand by
Find the settings menu in the TV. It sounds like you turned the green off completely. You can usually set the hues and colors and adjust for your preference or for lighting and such. Hope that helps.
Sreen keeps flashing when i turn it on why
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
The dvd is playing but the sreen is blank,there is nothing showing on the sreen,but the machine is running
... turn on TV? ... had to say that...
Is it on the correct source? Check to see where you have it plugged into the back or side if the TV (make sure it is an input and not an output) and then select that source in the TV menu.
Depending on type of TV, it will be Line 1,2, or 3... maybe 'Video' .... So many possibilities...
If that is not it.... might take it to a different TV and try there.... if it does not work try different cables, then assume the DVD is bad (is it just a DVD palyer and not a combo VHS/DVD player...?)
Peace,
Blue sreen with message sayin this is an encrypted channel
call Comcast and do nothing more. if they messed it up make sure they fix it or you could be out a tv and a cable box. if they wont then call the manufacturer of the tv.
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Light blue sreen
mine started at the left top now on right as well! anybody know whats up?
SOUND BUT NO PICTURE
I HAVE A PROBLEM ON SHARP 21 INCHES THE PROBLEM IS NO VIDEO BUT THERE WAS A SOUND IF I PUSH THE CHANNEL UP AND DOWN WILL DISPLAY OR VOLUME OK BUT NO DISPLAY BLACK SREEN
Top Universal Televison & Video Experts
vince
Jennifer Rock
Jennifer Rock
Are you an Universal Televison and Video Expert? Answer questions, earn points and help others
