Hi..
50/50 to get them back, you need to read the firmware flex, back it up, then flash the phone whit previous software version, and then right the flex file back as this will restore all your numbers.
have seen some cases that just firmware upgrading the unit would still keep the numbers but have seen other time that it did not save them.
www.UK-Repair.com
SOURCE: bootloader USB INIT
this happens to phones that have had water damage or something else and a way that might make it work is to take the battery out for no more than 60 seconds and put it back in and push the *,# and power buttons at the same time and if the blue screen comes up, while on the screen push the buttons and hold them until it goes normal. it worked for me
SOURCE: Blue screen Bootloader usb init
Goto google and look up Bootloader USB ini you will get results from Howards Forum telling you on how to reflash your phone follow the instructions.. Ignore the post about "V3M bricked but not hopeless" thats mine and its a different situation from yours. Good luck!
SOURCE: bootloader usb init
basicly the software is corrept.take it 2 a cell 4ne repair shop they will fix it it cost about 150.u cnt do it on ur own coz it takes a specail soft ware n only certain ppl have it
Get this Phone reflashed. Of course if you Dropped the Phone or if it went into water then Forget it about spending 35-50 Bucks on reflasing this phone. because it will go back to Boot Mode.
You may not have to send the phone out.I had the same screen and I got it by pressing the star and pound key I believe or the 1 and 3 keys or pressing the keys above that.It went away after I pressed them again.But I can't remember because I got to that screen by accident trying to remember my code to unlock the phone and start the phone to get it to work and stay on.
