The overhead display is powered by the same circuit for the overhead console, so if the vanity mirrors still work, chances are the fuse is fine.
Just in case, push the button a few times, to make sure the display is not turned off.
The overhead displays have a chance of the surface mounted resistors becoming unsoldered over time.
You can get one at a junk yard, or if you are good with a soldering iron, you can reattach the surface mounted resistors. Pull the overhead console down, and remove the display ( T10 screws holding the display to the console ). There are 2 plastic tabs holding the display together, release these.
On the back of the circuit board, you are looking for a resistor that looks like this :
