Question about York Fitness Z16 Treadmill
WHERE CAN I GET A MOTOR FOR YORK Z16 THREADMILL
MOTOR MODEL - YC268. SERIAL NO. Y5CB2E 008230. OTHER NUMBER ON ACTUAL THREADMILL IS 082640 SC
How do you replace a cracked running deck on a York Z16 treadmill ?
If you wish to get some details; check the site linked here. Pull up older posts.,,
http://electro-medical.blogspot.com/
Jul 24, 2016 | York Exercise & Fitness
I have different issues with threadmill
Sounds to me like the motor has a shorted field coil or open or shorted armature. The motor is bad, you can order a new one at the companies website.
Jun 09, 2014 | Nordic Track NordicTrack A2550 Treadmill
Where to buy replacement fuses for z16
Often these devices use the same style fuses ("blade style") as modern cars. YOu may find what you need at the automotive section of WalMart.
Apr 23, 2014 | York Fitness Z16 Treadmill
My York t302 threadmill motor starts to keep strange noise after some running. Motor has been changed once as well as whole threadmill. So this is my third motor and problem still exist. Here is the...
i just had a noise in my York T301 that sounds exactly the same as yours. It also came up with a E1 error code and stopped working. I pulled the motor hood off and noticed that the magnet in the drive pully had come dislodged. It was hitting the speed sensor near the belt. Glued magnet back in and all better. Hope this helps.
Oct 06, 2010 | York Barbell Home Use Fold-Up Treadmill
The treadmill starts then after a few seconds it stops and a code L5 or LS comes up. the model is a york fitness z16
More likely LS= Loss Signal open the motor shroud on the motor their should be a cylindrical shape sensor (magnetic). Plug in treadmill and on the motor control board their should be a L E D (red or amber) by manually rotating the motor you should see that light flicker if it does sensor is good if not replace sensor. Next thing if sensor is good check motor brushes to see if they are mis-align or worn if worn less than 3/8" in length replace them
Mar 09, 2010 | Exercise & Fitness
I have a error reading of l5 or ls not too sure york fitness z16
The L5 message means that there is a problem with the speed setting switches. Some models have one set of speed adjusting stitches on the handlebar and another set on the console. One of them is defective and is causing the problem.
Dec 29, 2009 | York Exercise & Fitness
I have a Jackson erie dess Dinky.The serial number is 04041727. I would like to know the actual model #, where and what year it was made and where can I get an ACCURATE wiring diagram for this sc/sc/hb 1...
Search this site based on how many pickups you have for a configuration matching your guitar.
Apparently some of these were 2008 models.It is possible the date code is imbedded in the serial number. That MIGHT mean it was made in Apr 2004.
You may find date codes on some of the internal parts. Thes usaull will be 2 digit year followed by 2 digit week of manufacture.
Dec 22, 2009 | Jackson Dk2m Dinky Electric Guitar
York Fitness Z16 Treadmill Logo
70 people viewed this question
Top York Fitness Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Tom Chichester
ray gallant
ray gallant
Are you a York Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
