SOURCE: BELT PLACMENT ON TROY BUILT TILLER MODEL
I am assuming your belt broke and you cannot find the replacement.
I had to go to an old timer that owns his independent business and he was able to find a much better belt than the one that came on the tiller. The Belt # is 1916657 and it is 25.5 inches long and 1/2 inches wide. It also has a kevelar core that will stand up to the constant gearing up and down.
Lowes was NO HELP AT ALL!!!!
Hope this at leasst get;s you in the right direction
SOURCE: I have a Troy Bilt Bronco 5.5 hp that will start
Sounds like fuel starvation
Check / remove carby / strip down / check for blocked jets for contamination.
Check spark is present.
Is correct heat range
SOURCE: Troy bilt bronco
clean and lube around butterfly arm and "windvane' under engine cover.most governors are controled by air coming off finns on flywheel also check to see if you have return spring broken or missing
SOURCE: Troy Bilt Rear tine tiller model 643 Bronco, won't
did it run out of gas when you added gas it could be that the fuel line has plugged up with something from the bottom of the tank take the fuel line off and try blowing threw it and take a air hose and blow out the carb and carb cleaner
