Question about Akai Mpk49 Mpk 49 Midi USB Keyboard With Mpc Pads New
<!-- from fixya rte -->How to fix usb port on keyboard controller - Akai Mpk49 Mpk 49 Midi USB Keyboard With Mpc Pads New
    Sergeant:
  • 308 Answers
I am assuming that you broke the connector off the pcb board? you need a soldering iron about 30W and solder and flux, to remove and short circuit after you solder them back on, using a magnifying glass to make sure none of the 5 termnials are shorted
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Posted on Aug 29, 2014
SOURCE:
How to fix loose USB on M-Audio Keyboard
Uscrew the case, desolder the USB socket from the circuit board. Buy a identical spare from any electronic shop using the broken one as sample. Solder in new USB socket.
USB sockets has only 4 connections - easy job.
Jul 30, 2014 | M-Audio Axiom 49 MIDI controller keyboard
Why are the Keys on my axiom pro 61 not sending MIDI messages?
Does your keyboard have a "MIDI OUT" port? If yes, then
there is a selection to choose between USB or MIDI OUT port.
For my M-AUDIO oxygen 61 (silver), I must press the [Advanced] button then Note F3 on the music keys manual to toggle the MIDI-OUT.
If set to INT, it will not sent via USB. If set to USB it will not send via MIDI-OUT port. To use MIDI-OUT port I need external 12V DC adapter.
Jul 29, 2014 | M-Audio Axiom Pro 61 Advanced 61-Key USB...
M-Audio MIDI Keyboard Controller's Loose USB Port
Open up and solder in a new Type-B USB socket. Get spare from any electronics parts supplier - it is a generic part. Just 4 solder points on PCB board.
Jul 15, 2014 | M-Audio Axiom 25 2nd Gen 25-Key USB MIDI...
How do I fix my Loose USB port on a midi keyboard?
If the port is still intact then it might just need to be resoldered. USB ports however to get strained and basically fall apart. Purchase another and solder it to the board. If you are not confident about doing this take it to your local Yamaha service centre.
HomeContact Us About UsAll CategoriesAmplifiersBanjoBaritone Horn...
If using link below please suply model number so correct part can be ordered. HomeContact Us About UsAll CategoriesAmplifiersBanjoBaritone Horn...
Jul 01, 2014 | Yamaha Portable Keyboard with 61...
Axiom 49 not detected by reason 5
Open preferences. Go to Control Surface tab.
Click Add. Select M-Audio as manufacturer.
Choose Axiom 49
Make sure the ports are set right.
Controls IN Port = Axiom 49 Hypercontrol In
Keyboard Port = Axiom 49 USB A In
Controls OUT Port = Axiom 49 Hypercontrol Out
if it hasn't detected yet then restart Reason.
Make sure the power on the Axiom is on.
If you still have issues the USB port on the Axiom could be bad.
Oct 01, 2017 | M-Audio Axiom 49 49-Key Semi-Weighted USB...
Hello guys, i have a problem with my midi keyboard. My PC doesn't recognize the USB connection and i can't find any solution.
Well first start by verifying USB port works by plugging in a hard drive or something thus proving you have a good port and USB Cable. At which point hook the keyboard up ( and make sure to properly install drivers provided on cd with purchase) being a pc this may take several attempts to install. What software are you trying to control? Reason? Logic? Fruityloops?
Oct 07, 2011 | Alesis Q49 USB/MIDI Keyboard Controller
How do i fix the usb port on oxygen 49 it seems to be loose . the keyboard powers on but is not being recognized.
The usual problem of these not being recognized is improper installaation or missing the driver software in the computer. The jacks sometimes appear loose but that can be normal. If you wiggle the jack and there is marginal connections, usually the computer will respond with the USB found and the disconnect tones. If the USB cable has been yanked, then solder could have been broken at the connector. Opening these units one has to be very careful to not damage the cables between the halves of the shell... also keeping track of the screws and type is a must.
Sep 07, 2011 | M-Audio Oxygen 49 USB Midi Controller
So, I have a controller keyboard, the MPK 49 that will not turn on via usb. the Display on the keyboard seems like it kinda gets power, but is not backlit at all.
The controller will not power from the USB. You MUST use a power adapter. The display takes far more energy than can be had from a USB port.
Dec 29, 2010 | Music
Akai Mpk49 Mpk 49 Midi USB Keyboard With Mpc Pads New Logo
1,239 people viewed this question
Top Akai Music Experts
Michial Gueffroy
Cameron Lewis
Cameron Lewis
Level 1 Expert
Bernie Scott
Level 1 Expert
Are you an Akai Music Expert? Answer questions, earn points and help others
