SOURCE: IN CANON IR2270 SHOWS ERROR CODE E0049001
there might be something jammed in it like paper so check all the compartments or the ink section if thats not hte case then get it checked out by a professnial
SOURCE: canon ir5070 i have an error code e100-00001 what does this mean
E100 code
Laser Shutter not opening
Possible mechanical failure or cracked/damaged Primary Fan Duct preventing the Laser Shutter from opening fully.
you have the wrong ADF installed on your machine this is the error code E490-001
if this is the code then you have the wrong ADF on the machine ther is no E049-001 code so i figured it was a E490
SOURCE: my canon pixma mp830 shows error code 5010. what
The scanner lock switch may be in the locked position. Lift the cover and check the slide switch located on the top front left. If this is not the problem, you will have to have a service center look at the problem.
SOURCE: what does an error message E000007-0000 mean for a
Error Message e00007 code means that the fusing film is out of Home Postion or the film is ripped. You will need to most likely have the fixing film replaced. You are proble going to have to get a service to repair it.
