I have a 52 xbr4. Recently, my screen flickers on and off. Screen goes black and the comes in and flickers at different rates. If I press the MENU button on the Sony (not a cable box menu), like you suggested above, the tv does not flash or flicker. When the menu screen goes away, it flickers again. I have tried turning the tv off and back on again. Sometimes it works, sometimes it doesn't. I've unplugged the TV for a while and turn it back on. Sometimes it works and sometimes it doesn't. I have no idea what this. I love the TV... No problems until this. I'd hate to have to get a new one. Can you help?
Fault with the main power supply regulator board. Ubnormal DC voltage output from it. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
SOURCE: FLICKERING PICTURE
Check power supply for the 24Volts connected to the backlight inverter ,bad caps could be the fault
SOURCE: new sony tv screen flickers. other tv's in house
check the following
if your picture settings are okay
check your signal in put connection for a dry joints.
or cable connecting that tv.
SOURCE: Power on - Screen Black non responsive
U might get the tv working again,by unpluging it,replug an hour later let the tv reset it self.Not,Than the Tuner board,it the board u should looking into replacing.Not the power supply board is good,because u getting a solid power LED indicator light.
SOURCE: Sony Bravia No signal plus flickering image and
You know how to reset the tv to its factory setting, I think you are a technician. Second thing you can do is software update. Go to http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL42V4100&LOC=3#div_pos_30 . If it doesn’t work. Replace the Main board (UB board). Part # A-1547-086-A Cost approx $320.
Knowledge obtain from: Repair experience on same symptom.
Parts reference: Andrews electronics, 800 289 0300.
SOURCE: I have 46 inch sony
I
am afraid I have some bad news for you, I honestly feel bad giving it
to you because I know its not what you want to hear. Hopefully if you
follow my advice you can get a good outcome here.
I
believe there is about a 98% chance you have a bad LCD panel, without
physically diagnosing the tv I cannot be 100% sure but I am very sure
that you do have a bad LCD panel. The LCD panel, if you don't already
know is the actual viewing surface for the television. The reason this
is such bad news is that the part cost is over $1200, and labor is
around $400 to have one installed. This is most likely more money than
it would cost to purchase a new set today.
Now the only
thing I can suggest to you is to call Sony and complain. I have seen
many people get a positive result by working with sony, especially since
the tv is only 3 months out of warranty. What you will need to do is
first get a sony authorized service center to come out to your home (you
can find one on sony's website) they will need to give you a written
estimate with the parts and labor broken down. Once you have that paper
you can call Sony and begin working with them to get the repair fully
covered. I cannot guarantee you that they will fix it, but I have seen a
lot of people call Sony and work their way up the ladder and end up
with the repair being fully covered.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
