Some replacement charts list the 12YC, & others the 14YC.
SOURCE: have a 16k propane guardian generator have to manually start and
Is this an RV generator?
If you have to really choke an LP engine but it runs more or less normally once started you need to troubleshoot the demand regulator and the fuel supply lines (look for air leaks). I'd also check the fuel inlet pressure before the demand regulator.
Rate me,
Carl
Tune Up
Spark Plug
AWSF-42C
Spark Plug Gap
0.044
Ignition Timing
10 degrees BTDC
Firing Order
1-4-2-5-3-6
Distributor Rotation
Clockwise
Valve Clearance Intake
0.014
Valve Clearance Exhaust
0.016
