Apr 17, 2012 - Go to Dewaltservicenet.com and in the middle of the page towards the bottom type in the model number 1710 and it will go to another page ...
Find all the parts you need for your Black & Decker Miter Saw 1701-1/TYPE 1 at RepairClinic.com. We have manuals, guides and of course parts for common ...
This article is a troubleshooting guide for problems and malfunctions common to most electric power tools. Tool Diagnosis: Is it the Brushes or the Switch? This ...
Electric pressure washers have a switch that cuts off the power when the pressure builds up after closing the trigger. In my case that is how I got my washer. The switch stuck in the open position thereby not letting the motor start back up. I took the covers off until I found the switch which had a stem sticking out that I could push back to operating position. I was able to drill an access hole in the cover so I could push to reset my switch because I didn't have a parts list to get a new switch. When you get the covers off you can check the switch with a meter to see if it is open and possibly reset it manually for a test to see if that is the problem. The switch should be replaceable. I hope this helps.
check the unloader valve (pressure relief valve) probably need to replace the o-ring. it should be on the side of the pump and have a large spring. just unscrew and replace. hope this helps.
