Nextar MA933A MP3 Player Logo
Posted on Jul 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Right earphone wont work.
My mp3 emits sound from my left earphone perfectly and I have to sometimes twist the wire of my earphone to be able to hear sound from the right side. I also tried replacing the earphones with a new pair and the problem still continues to occur.
Anonymous
Level 2:
  • Expert 67 Answers
  • Posted on Jul 02, 2009
Anonymous
Expert
Level 2:
Answers
67
Questions
0
Helped
27909
Points
107
It is very likely that the problem is in your MP3 player and not your ear phones. If it is still under guarentee, then take it back to where you bought it. If not it may be that the earphone jack plug is faulty? It is a trade off between the cost of repair against the cost of a new one. These things are often glued together so opening it could break it anyway - sorry
Earphone-only left earphone works... how can u repair right earphone
Rotating the jack or twisting the wire joint on the headset might work.
How to fix coby cv320 headphones
If you hear sounds from only one earphone then most likely there is a broken wire to the earphone that is not producing a sound.
It is difficult to determine exactly where the wire is broken and repair. I suggest you get a new earphone.
Can only hear from 1 side of earplugs on my electro brand mp3
three possible scenarios, either the balance ( left/right) setting of menu are set to favor right vs. left. the earbud cable is not seated properly or defective sometimes the earphone jack itself on MP3 is not making contact, or broken speaker inside earplug
My earphones' audio isn't right. I have to twist the wires to get it fixed. Sometimes, it only has sounds on the left or on the right or nothing. What should I do?
You have fault in the wires that has been twisted and open/ shorted within losing the connectivity. The best thing is to get this replaced if you can do the work by yourself, you will have to buy the shielded twin core wires, one headphone stereo jack, open the earpiees carefully- it is tricky,so do it gently, solder the wires in accordance with the lead and shield on either sides and then connect to the stereo headphones. Hope this wil work out for you. Good day
2answers
The MP3 player earphones only work sometimes. Left will work the right doesn't, the right works the left doesn't. Somethimes if you move the MP3 player, neither one of the speakers work. We purchased new...
Sounds as though either the earphone's Plug isn't the right size or plug end shape... OR the actual Jack is faulty, and only making intermittent connections... or the wire to them is broken. What is best is take the MP3 unit along when buying any head/earphones and try them in shop.. As for Walmart... Talk to a manager and demand a refund or a change of type... Don't take NO for an answer. Also you don't need to spend that amount for them... any cheap pair that works will be OK. Try before you buy.
Sound from 1 side only!
your ear input female jack is stripped try another new pair of earphones if not you may have to take it in for service.
2helpful
2answers
Earphones right side won't play...
I inserted a drill bit that fits the exact size of the aperture and twisted it around a few turns and it is working better.
Heath Robinson eat your heart out
1helpful
My earphones keep losing and regaining sound!
the wires in your headphones are broke my sugestion is to get a new pair
1helpful
5answers
Earphones stop working
I had this very problem. The Sansa worked great for over 1 year, but then I started getting some dropping out of sound on the left side. Today I went to an electronic shop and they opened up the unit. There was a small crack in the solder of the earphone jack on one side. So the electrician just used a fine point solder and fixed that, then strengthened the other solder points of the jack to make sure it won't happen again... I hooked in the earphones....and it is PERFECT again!!!! So, don't lose hope...just take it in to a decent electronics shop and they will most likely be able to fix your problem. And he only took around US$10 for the job. Beats buying a new player...
Top Nextar Audio Players & Recorders Experts
ADMIN Andrew
ADMIN Andrew
 Grubhead
Grubhead
Vinho Xie
Vinho Xie
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
