SOURCE: i cannot format my memory card. i need the PHONE LOCK CODE.
you could just pull out the card and connect it to your computer and
format from your computer or u could download a program called Card
Export II just install it then connect to pc via usb cable then press
connect on the program then go to my computer and you will see
"removable media" just right click that go to format...and you should
be good to go
program found here
http://www.softick.com/smartphone/cardexport2/
SOURCE: i need to format my phone so i can store music on
If you forgot ,you can generate master code using your IMEI, which can be viewed by pressing *#06# and keying that in the link mentioned below,,
http://www.unlockme.co.uk/master.php
Hope this is ok.
Testimonial: "thanks for the help but i fixed it already. i just kept googling and someone mentioned i should try the last 4 digits in my phone #,and it worked. :)"
SOURCE: I am trying to format my memory card for my lg
The phone lock code is the security code that you set on the phone. If you did not set a security code then it is the last 4 digets of your phone #
SOURCE: How do I format my sd memory card so I can save pitcures from the phone to the card?
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
