1999 Chevrolet Tracker Logo
W
William Talton Posted on Aug 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What's the best way to access the Oil Sending unit on a 99 Tracker for repair / replace?
Oil drips rapidly from sending unit
Richard Warren
Level 3:
Genius:
  • Chevrolet Master 2,548 Answers
  • Posted on Sep 01, 2014
Richard Warren
Chevrolet Master
Level 3:
Genius:
Answers
2548
Questions
Helped
640815
Points
6606
The sender screws into the side of the block or filter housing , idle the engine and look for the oil dripping , it just unscrews .(Fit new one ).
  • 8 more comments
  • _-__-___-_
    _-__-___-_ Sep 26, 2014
    which engine, the V6, i have, remove left wheel, this gains access to left side of block and sender, need drawing, ask, i have 2 Full FSM , one in book and one on CD and PDF.
  • _-__-___-_
    unscrew it and replace it,
  • _-__-___-_
    here is the exact location on H25 engine (v6)
  • _-__-___-_
    10 inches to the leaf of the oil filter, is the filter leaking? are you guessing? there are other leak points. for sure.
  • _-__-___-_
    http://www.fixkick.com/engine/2.5L%20200...
  • _-__-___-_
    see page 28 , component ID 26, is this clear ? sure it is.
  • _-__-___-_
    finding oil leaks takes skill, as the wind there, is huge and gravity , + wind = choas....... on all cars. clean it and find it.
  • _-__-___-_
    if j20 or G16 engine, same place. the j20 sender is to RIGHT of filter.
  • _-__-___-_
    passenger side means zero in the world wide web, in usa it right, in UK its LEFT so, avoid it. use RIGHT aND LEFT.
  • _-__-___-_
    or LHD passenger, side. dig?
5 Related Answers
Anonymous
  • 31 Answers
  • Posted on Jan 18, 2009
SOURCE: Can not find oil pressure sending unit on engine.
yes it will be on the lower part of the engine block. i believ on passenger side.
Anonymous
  • 373 Answers
  • Posted on Jul 13, 2008
SOURCE: 2001 chevy venture oil sending unit
HI..
On a problem with oil pressure sensor leaking.
99% you need to replace the sensor with a new one.
Because if you can see the leak is not for the tread or gasket of the sensor.
If you can disconnect the the wire from the sensor.
and try to start you will see the leak coming from inside on the plastic, where the pins. of the sensor.
OK.. I hope this information work for you.
I work on Cars everyday.
Thank you fo use fixya.
A
Anonymous
  • Posted on Nov 07, 2008
SOURCE: oil sending unit
I have heard sludge buildup can be an issue with Dodge engines in Durangos. Make sure sludge is not blocking oil flow and reducing pressure.
Anonymous
  • 15935 Answers
  • Posted on Apr 23, 2009
SOURCE: changing the oil pressure sending unit on a 1996 2.2 pontiac sunf
Under hood, driver side, front engine area, below cylinder head, where engine meets transaxle housing mounted in block
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Anonymous
  • 323 Answers
  • Posted on Jul 20, 2009
SOURCE: 95 grand cherokee oil pressure switch
Use a deep well socket and extension, it lives by the distributor.
2answers
My 1996 Toyota Camry is leaking oil in little spots on the ground when its parked, where could it be leaking from and how can i fix it?
You cannot repair the leak until you determine where it is leaking. More than likely it is leaking from the oil filter, oil pressure sending unit, or valve cover gasket. Check around the oil filter for a leaks and if you see oil on the filter then replace it. Check the oil pressure sending unit and if it is leaking replace it. Wipe all the oil off the bottom of the engine and any other place you see oil. Now place newspapers on the floor under the car and then start the engine and let it run for about 10 minutes and then shut down. Wait overnight and you can see where the leak is coming from.
1helpful
Oil leak front of engine
Might be a couple of things. If it is engine oil, might be the front crankshaft seal. Also, make sure your valve cover is not leaking and dripping down the front. You may have to pull off the timing cover to see if there is a leak underneath that. And check the oil pan gasket, oil filter, and possibly the sending unit. I always like to clean off the area as best as possible with a power washer or equivalent, so I can get a good look at where the source of the leak may be. take care and good luck. ps, did you check your power steering pump and lines, if you have power steering.?
1helpful
Engine oil leaking near sending unit. Replaced unit and oil still leaks. What could be the cause?
Look up overhead above the sending unit for any oil that maybe dripping from above,makeing you think it's the sending unit leaking. If not then you may use a little thread sealer to seal the leak. Also check to see if the sending unit is loose and the threads may not be the same as the old unit you removed (metric/standard/pipe) Hope this will help you.
When my 1996 old aurora get up to temp about 220 the dash warns me my oil pressure is low. AT stops it can drop to 5 to 7 sometimes lower.
see if your oil pressure sending unit is leaking it should be located close to the oil filter. pull the plug off the sending unit to see if oil drips out. if so replace it.
Oil pressure light flashes intermittily. oil level is okay.
HI. I would advise to have the oil pressure sending unit(sensor), and oil pump inspected immediately for faults. If the oil pressure sending unit is operational , and the wiring is ok, replace the oil pump and screen.
To verify proper oil pressure, i recommend purchasing a manual oil pressure test kit form your local auto parts store. This will make it easier to isolate the actual issue.
NOTE- The most common error will be a faulty sending unit, or sensor(oil pressure)
2helpful
Where is the oil pressure switch
The sending unit is going to be down by the oil filter. It should have some wires running to it. If you don't have enough room to access the sending unit easily then you can purchase a special socket to extract the old sending unit. Good luck.
Where is the oil pressure switch on 99 ford explorer
You will find the sending unit next to the oil filter underneath. There will be a couple of wires going to the sending unit. Unplug the wires. You might need to purchase a special socket to remove the sending unit if you don't have easy access to the part.
2answers
Oil pressure gauge reads 80(pegged),,oil tepm is 207....car runs great
it is probably the oil sending unit if you have access to a direct reading oil pressure gauge put it on and if oil pressure is reading normal replace sender
2helpful
What is a oil sending unit on 99 chevy venture van?
easy to change u just need a special tool for removed on front of motor at right of oil filter its look like a coolant sensor or a little bottle with a connetor removed the connector and take the tool to remove
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
