SOURCE: Error #B03
UNFORTUNATELLY.....
Io sono un tecnico ed ho voluto APRIRE !!!
c'è un errore di progetto !!!
KODAK CI HA FREGATO!!!
esiste una batteria nascosat interna (quella che tiene la memoria foto ed impostazioni) che NON é sostituibile.
Quando questa si esaurisce la macchina può anche essere buttata, visto che il costo che dovremo subire per sostituirla tramite un centro specializzato è superiore a quello della macchina stessa: siamo vittime di una truffa !!!!
Stefano
SOURCE: B03 error code on kodak easyshare one 4mp digital camera
THe issue of the camera shutting down and the lens Extending is an internal malfunction. UNited Camera Repair has been able to fix this, at least for me, they did. They replaced the main board and the camera worked when I got it back. Otherwise, if you dont want to spend the money, its a gonner..
SOURCE: Kodak Error B03
Either your PCB board is damaged, your batteries are old, or your AC adapter is providing higher voltage than the required 3 volts.
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
