A
Anonymous Posted on Aug 28, 2014
I have cannon lbp2900 and how to print mirror image
Mirror image
EMILIO
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Aug 28, 2014
EMILIO
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
Helped
2845
Points
40
With Canon driver I think it's impossible
You have to copy the image on paint and then use the options to mirror image
4 Related Answers
pennyfreese
  • Posted on Dec 02, 2008
SOURCE: Printing a mirror image
Click on the image and copy and paste it. Take the pasted image and select Format and Flip image. You can then delete the first image and keep the new mirrored image.
I hope this works for you.
Anonymous
  • 220 Answers
  • Posted on Jun 20, 2009
SOURCE: how to print mirror image with Cannon Pixma ip2000
  1. Click the Printer and Paper tab.
  2. Under Paper, in the Size box, select Letter.
  3. Click OK.
  4. Do one of the following:
    • If your design is a picture, clip art, or WordArt, flip it horizontally.
    default.aspx?assetid=za790050011033How?
    1. On the Arrange menu, point to Rotate or Flip.
    2. Click Flip Horizontal.
    • If your design includes text in a text box or table, turn it into a picture first, and then flip it horizontally.
    1. Select the text in the text box or table in your design.
    2. On the Edit menu, click Cut.
    3. On the Objects toolbar (toolbar: A bar with buttons and options that you use to carry out commands. To display a toolbar, click Customize on the Tools menu, and then click the Toolbars tab.), click Insert WordArt default.aspx?assetid=za060452451033.
    4. Under Select a WordArt style, click a style, and then click OK.
    5. Press CTRL+V to paste your text into the WordArt Text box.
    6. Format the text, and then click OK.
    7. If necessary, resize the WordArt, or use the WordArt toolbar to format it, and place it in the design.
    8. Select all the objects in the design, including the WordArt.
    9. Click Group Objects default.aspx?assetid=za060447801033.
    10. On the Arrange menu, point to Rotate or Flip, and then click Flip Horizontal.
  5. Print your design on plain paper first to make sure it looks the way you want it to.
  6. Make any adjustments to your design after seeing the test printout.
  7. Make sure thermal t-shirt transfer paper is in the printer.
  8. On the File menu, click Print.
  9. Select the options you want.
  10. Click OK.
Source
Cheers
pineworks
Clive
  • 4362 Answers
  • Posted on Apr 25, 2010
SOURCE: how to I print in mirror image on Cannon MP620B
Hi there
You need a program that you can use on your PC with this program you scan it to your PC and then print it out, ok you need a program like art or photo or paint or some thing like this that have a scan in it.
And will also be able to mirror it with this program. Also there are some other program that is called T-shirt printing Factory program.
Read more below.
The best program to put on your Pc is what I use and it is Free you, it is called PagePluse SE, you should try it you can do all sort of things with it but there no scan on it, just scan your photos to the your pc with another program witch has scan on it and put them in the SE program and you can do any size you wont and after adding text to it or backgrounds you can send it to the printer and print, an other program I use for scanning from the printer to the PC is called PainShop Pro 7 witch is a old program there newer ones out now but I am happy just using the old one it does the trick.
The Free version is Called PagePluse SE you not need the version 9.
Ok here the link to download the PagePluse SE program and it not a free trial it a free, there is one you can Buy but this is all you need download the free one it just as good.
Click Link = http://www.freeserifsoftware.com/software/pageplus/index.asp
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Anonymous
  • Posted on Jul 14, 2012
SOURCE: HOW DO PRINT BOTH SIDE
how to print odd pages only
1helpful
Which printer print mirror image?
If your printer won't print mirror image, try editing the document so that the mirror image appears on your screen. All printers will print that.
I know MS Word has that capability.
I hope that is of help.
Is there any kind of option to print on both sides in Canon LBP2900 printer?
To print both side automatically you need a hardware called Duplexer. Cannon Laser Shot LBP-2900 dont support Duplexer. You need to manually turn the paper everytime.
Regards,
Shrey
39helpful
3answers
3helpful
Can i have a mirror printing on canon lbp 2900
I have cannon LBP 2900 Printer. I have to print my text into mirror Image. Can you suggest me about it ?
2answers
HOW DO PRINT BOTH SIDE IN CANNON LBP2900
you can print both sides only by using "manual" duplex. :)
5helpful
2answers
How to print on both sides of the paper in canon lbp2900?
what is the option to print bothsides in cannon lbp2900
2answers
Canonlbp 2900 english version needed
call recon and they will gave u the steps for fixing it
7helpful
3answers
k24674
ADMIN Andrew
ADMIN Andrew
