Bought replacement battery. Says charge complete while plugged in, but won't power up after unplugging.
Melissa-
Your best bet would be to contact Iridium Products Iridium 9505A Satellite Phone
Mark
Motorola Support
SOURCE: Battery wont charge!
Looks like the batteries are DOA (dead on arrival). Happens sometimes. Since you said you just bought this yesterday, take it back to the shop.I'm sure they will be able to replace it for you.
An other thing, make sure there is no plastic around the battery or the contacts..Sometimes that can be a problem too..
Cheers!
ID
SOURCE: phone won't charge
try charging with the flip open and watch what it says.
otherwise a new battery might be needed
SOURCE: My screen will turn on, but will not proceed.
hi it seems you have a prob in the keypad flex. have it replaced and your prob is solved.
SOURCE: Motorola V3 keep shutting down
Try a new battery if that does not work then you should take the phone and have the firmware flash to correct this error.....take the phone to a mobile service center to have this done.
SOURCE: Battery is charged, but only
First, I would suspect a bad battery. Try changing it with a known good battery. Check the metal contacts on the phone and the battery to make sure they are clean and damage free.
