SOURCE: casio fx-82es significant figures
it should...
it can be found by SHIFT then MODE then SCI is the one you want to choose
SOURCE: I need a manual for my Casio fx-260 solar calculator.
I have the User's Guide for fx-260SOLAR calculator
The manual is similar as for fx-82Solar calculator.
In Guide thei recomendet : http://world.casio.com/edu
But website has moved to http://edu.casio.com/
Nataly
SOURCE: FX-9750GPlus Calculator: I want to solve the goodness of fit problem on my ...
Part A shows you how to enter your data and calculate some statistical values.
PART A
In the main menu select [STAT] icon to enter Stat mode and display the
statistical data lists. Use the
satistical data lists to input data and
perform statistical calculations. Use the arrows to move the
highlighting around the lists.
Exemple: Enter the following values in List 1
1st line enter 90 [EXE]
2nd line 85 [EXE]
3 79 [EXE]
4 75 [EXE]
5 70 [EXE]
6 68 [EXE]
7 56 [EXE]
When finished you press [F2:Calc], then [F1:1Var] and the statistical
results appear on screen.
Title of screen : 1-Variable
x bar =74.7142857
Capital Sigma x= 523
Capita Sigma X squared = 39851
x lower case sigma n = 10.5249945
x lower case sigma n-1= 11.3682934
n = 7
Scroll down with Down arrow to access other data
minX =56
Q1=68
Med =75
Q3=85
Xbar -x lower case sigma n =64.1892911
x bar + x lower case sigma n = 85.2392802
maxX=90
Mod=90
All you have to do now, is to look at the theory you learned and
interpret what these values mean.
PART B
SOURCE: Casio fx-9860G graphics calculater, vertical line segment
I am not sure how you can create such function (the range limitation do not work for x=c) but you can draw a vertical segment, just do not call it a function.
Draw a graph Y1=0
Then press SKETCH function key and use the F6 key to cycle through the TABS at the bottom of the screen. Look for the TAB named PEN. and click the function key below it.
Use the arrows to move the cursor to a spot on the screen (near the bottom), Press EXE to fix the starting point of the segment. Then use the Up arrow to draw a vertical segment from bottom to top.
