Boxing Logo
A
Anonymous Posted on Aug 28, 2014
Power steering leaks fluid around pitnom arm
Dwight Beard
Level 2:
Sergeant:
  • Expert 333 Answers
  • Posted on Aug 28, 2014
 Dwight Beard
Expert
Level 2:
Sergeant:
Answers
333
Questions
0
Helped
69597
Points
976
Hello, I think your sector gear (steering gear box) needs to be resealed to stop that leak.
1995 gmc suburban leaking power steering fluid at end of I think is steering column that hooks to something else but there is rubber seal like that is breaking apart that connects the 2 parts together? I...
Sounds like the pitman arm. See #5 on diagram below. It has a ball joint with grease that is held in with a boot. It the boot is cracked open, you should replace the arm. You will need an alignment after replacing the arm. The arm does not contain any steering fluid, so if that is leaking, you have another seal broken somewhere...
1helpful
Power steering tank wont hold fluid and leaks out beside driver tire
Sounds like a blown power steering line. To confirm, wipe down all surfaces around the power steering unit including the lines. Replace the power steering fluid and start the engine. While 1 person is inside the truck, have them turn the wheel from side to side while another watches the area around the power steering unit paying very close attention around the lines. The high pressure line is the most common cause for leaking fluid. If there's no crack or kink in the line, the issue may be the fitting itself where it connects to the power steering pump. Both parts are pricey but replacing the high pressure line (about $150 at the dealer) is certainly less expensive than replacing the whole power steering unit itself.
2answers
The steering is hard to move and the steering warning light is on. Please let me know what to do I need to urgently resolve it.
The servo unit on the steering has failed . Look inside the engine bay for oil leaks - if none are present then the entire steering rack will have to be replaced - the internal seals have failed.
2helpful
Have a very slow power steering fluid leak. thoughts as to where it could it be leaking from?
The top of your power steering pump where the steering arm via ujoint is a seal, otherwise known as the power steering top seal is most likely seeping out, see if you can wipe it really good and trying driving it some, and then wipe it again, if fluid on top in, seal needs replacing, also check housenthatngo down to your steering area for leaks. Let me know, thanks Mike
3helpful
4answers
My 94 Jeep grand Cherokee power steering fluid is leaking. I fill up the fluid and a day later the fluid is all gone.
The lines coming off the unit are probably to blame, one is a high pressure line. Look for leaks around the fittings on both lines.
2helpful
3answers
Steering hard to turn to the left like power steering is out but turns ok to the right. Checked power steering fluid. It is OK
bad steering problems,,your steering rack most likely,but,have you recently been stuck in ditch? when wheels are straight, look at front of car when parked. do wheels look funny? one going one way, and the other going the other? may be alignment. is it leaking any fluid on either side of the front of the car? drivers side? passenger side? if it's not out of alignment,,,wheels out of alignment,,the steering rack is the problem. it may be faulty. if not leaking fluid,it may still be bad. first i would make a visual test look under the vehicle while someone turned the steering wheel to right and left while car is in park,emergency brake on!! look at the steering arms while they turn the steering wheel from right to left. no fluid leaks? any resistance in turning the wheel? any leaks,if so,go to leak and repair with steering line replacement.no leaks? suspect a bad steering rack. hope this helps and thank you for choosing fixya.com i love to volunteer
2helpful
The power steering isn't working. The reservoir was empty and I added power steering fluid and it still very hard to steer
YOU HAVE A RUPTURE PRESSURE LINE IF YOU HAVE NO POWER STEERING FLUID IN THE POWER STEERING RESERVOIR.LOCATE LEAK THEN BLEED POWER STEERING SYSTEM BY ADDING POWER STEERING TO RESERVOIR.DONT OVER FILL BY FULL COLD MARK ON POWER STEERING DIP STICK.ADD FLUID TO RESERVOIR WAIT A 2 MINUTES.CHECK FLUID LEVEL AGAIN.WHEN POWER STEERING FLUID LEVEL STOP DROPPING.START ENGINE LET IT RUN FOR 10 SECONDS.THEN TURN OFF ENGINE CHECK POWER STEERING FLUID ADD FLUID IF FLUID LEVEL DROPS. WHEN FLUID LEVEL STOP DROPPING.SAFELY RAISE SUPPORT VECHICLE FRONT WHEELS.START ENGINE.NOW TURN STEERING WHEEL GENTLY FROM STOP TO STOP MEANING LEFT TO RIGHT DONT HOLD IN POSITION.LET THE STOP TO STOP BE QUICK.CHECK POWER STEERING FLUID AFTER YOU HAVE TURN STEERING WHEEL ABOUT 7 STOP TO STOP.WHEN FLUID LEVEL STOP DROPPING YOU AT HOT MARK ON DIP STICK BLEEDING PROCESS COMPLETE.TURN OFF ENGINE LOWER VECHICLE BACK TO GROUND WAIT ABOUT 5 MINUTES CHECK YOUR FLUID LEVEL.IF FLUID LOOKS LIKE A TAN COLOR.YOUR POWER STEERING SYSTEM FULL OF AIR.TURN OFF VECHICLE LET VECHICLE SET A LONG WHILE TO AIR BUBBLES SETTLE DOWN LOOK FOR LEAKS AROUND POWER STEERING PUMP FRONT SEAL AND CHECK FOR LEAKS AROUND POWER STEERING LINES.
1helpful
Power steering gearbox leaks fluid at the pitman arm. Can the seal be replacedin place? how?
The pitman arm seal can be replaced by removing the pitman arm, prying out the old seal and driving in a new one. However, usually when the seals start to leak it's from a bad bearing or excessive play in the steering box.
1helpful
2003 Ford F350, massive hydrolic pwr steerinfluid leak
What I think you are referring to as the pump is really the steering box because the pump doesn't have an arm connected to it. The pump has 2 hoses and a belt going to it. From what you describe it sounds like you need a pitman shaft seal. The seal is replaceable but you will need a pitman arm puller to get the pitman arm off. If you don't have or can't get a puller don't even bother starting the repair, as you WILL NOT get the pitman arm off without one. When you get the pitman arm off clean out around the shaft and you will see a snap ring. Remove the snap ring. Now make sure the power steering is full of fluid. Start the engine and turn the steering wheel all the way one way or the other and hold it there while increasing the RPM. Doing this will literally "BLOW" the seal out. There will be a couple of spacers and maybe another seal that come out of the hole also. So read the installation instructions that come with the seal kit and it will have a picture of where the components go and in what order they go in. Don't forget the snap ring. When done replaceing the seal you have to center the steering box. From all the way one way turn the steering wheel all the way the other way and count the turns. Now turn back the other way half as many turns and the box is centered. With the tires pointed straight (not turning) the pitman arm should go right on. The pitman arm will go on the pitman shaft in 4 different places. So if you don't center the box and the wheels you might have say one turn to the right before the steering wheel stops and three turns to the left. With all this done fill the power steering with fluid. With the front tires off the ground and the engine NOT running turn the steering wheel all the way from stop to stop 4 or 5 times and then check the fluid again. Fill the fluid and turn wheel from stop to stop another 4 or 5 times. Doing this will "bleed" most of the air out of the system. Now start the engine and turn wheel from stop to stop a few more times to "bleed" any remaining air from system. Turn off the engine and check fluid level. Hope this is helpful.
Top Boxing Experts
NOEL
NOEL
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
ENFORCER
Are you a Boxing Expert? Answer questions, earn points and help others
