Clear error code c4601
Could not fine C4601 do you mean c4701?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Clearing a service code ''C0400'' on a Minolta CS Pro 6001
C400 is exposure lamp fails to come on, on start up the main exposure lamp should come on and do a scan.
If the lamp is not detected by the sensor, then you get the code.
Restart the machine, watch for the exposure lamp. if it does not come on before the code occurs, then the lamp or thermal fuse is likely gone.
if the lamp comes on then the code, the AE sensor is likely gone.
Hope this is of some help.
Ed
SOURCE: "Can't Detect Genuine Toner Cartridge"
minolta printers work on "chips" if the chip atached to the cartridge is not original minolta you better change it.
SOURCE: How do I clear error message C-2558 for the Konica
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
SOURCE: how to clear error code c 3421 on konica bizhub
C-3421 = Fusing heaters trouble
To Reset:
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If error code returns a technician is needed to replace fuser section. Call local dealer with error code and tell them to make sure a tech brings a fuser assembly.
