SOURCE: Samsung 32'' LCD TV backlight works occasionally
Check for any loose soder points or loose connections with wiring sockets to backlight inverter board.
SOURCE: Samsung LCD TV backlight switched off
Most likely you will need to get a diagnoses done on the set. It could be a faulty 24vdc circuit (power supply capacitors), defective inverter, or a failing CCFL backlamp.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
