NorStar T7316E Corded Phone Logo
A
Anonymous Posted on Aug 27, 2014
<!-- from fixya rte -->Where is rls button on T7316E - NorStar T7316E Corded Phone
Norm Pearl
Level 2:
  • Expert 108 Answers
  • Posted on Aug 28, 2014
Norm Pearl
Expert
Level 2:
Answers
108
Questions
0
Helped
55256
Points
211
It's the little orange one with the picture of a hung-up (facing down) handset on it.
Nortel T7316E how to listen to personal greeting
feature 981
Enter password
press OK
Press GRTG
PLAY (or record new one)
Hit RLS to end the session.
HOW DO I CHANGE THE DATE AND TIME ON A NORTEL T7316E
You should complete programming on a T7316, T7316E, M7310, M7324 phone.
1. Feature **23646
2. Password: 266344
>>>Your password may have been changed by your phone company. Contact them for the password.
3. Select General Admin
4. Select Date and Time
5. Select Time
6. Adjust the Hour, Minute, and AM/PM
7. Press Rls when done
How do you set caller id to show before you pickup on the nortel t7316e
Feature **CONFIG,
Teeminals&Sets,
enter set #,
Telco Features,
1stDisplay,
use Change softkey to cycle between Number, Line, Name
Rls to exit programming.
You need a CI line card in the KSU.
5helpful
How do I set the time on my T7316E phones?
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___" 18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
3helpful
How to change the time and date on nortel phone
Programming2.gif is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say A. Configuration. The 4 top line/feature keys are now used for programming.
display should read B.General Administration.
Press the show key (top right arrow)
display should read 1.speed dial
Press the next key 2 times(bottom right arrow) .
display should say 3.time and date
display should show current programmed time
Press the Change key
Enter in time in 12 hour format
press ok
press either Am or PM when prompted
press ok
press the Rls key when finished
1helpful
PHONE LOCKED ON T7316E
To reset a subscriber mailbox press feature 983, enter in log (default 1020000), on the 3 soft keys bolow the the screen press mbox,chng, enter extension number of the locked mailbox, press reset at the reset password prompt.press rls key
I need to change the phone extension and I don't remember what feature to use. I tried feature **config, but i didn't find any option for changing the extension.
the change Dn program is under the system programming heading.
feature**266344>266344>system prgrming>change DNs> enter old dn>enter new dn>RLs
30helpful
Nortel T7316E need to reset all the password
How to Change a Mailbox Password 1. To access the voice mail system press Feature.
2. Press 9 8 3.
3. When you see Log: enter ~ SETNNA (738662) and press OK
4. Pswd: CONFIG (266344)
5. Press "MBOX".
6. Press "CHNG".
7. Enter the mailbox number you wish to reset.
8. Press "Reset".
9. Press "Rls" to exit (orange button to the right of the number buttons).
Default password is "0000".
1helpful
How to set the time on our phone
Follow the instructions listed below. You shouldn't have any problems
Step 1
Press the FEATURE key followed by **8463
Password Retry Step 2
Press 266344 on the dial pad buttons to enter the DEFAULT password. Your password MAY BE DIFFERENT! The display will show the following options:
Hour: 01 Next Change Step 3
Select CHANGE - the display will show the following options:
Hour: __ Cancl Step 4
Use the dial pad buttons to enter the hour. You must use two digits for all hours (i.e. "08" for 8 o'clock). You will be prompted to enter AM or PM. Select CHANGE and OK to choose PM. AM OK Change Step 5
After you have entered the hours, select NEXT. The display will show minutes as 00. Use the dial pad buttons to enter the minutes. If you are just changing the time, press the RELEASE (RLS) button to end your session. The time will be changed and the date will remain the same.
If you want to change the date, select NEXT.
Minutes: 00 Next Change Step 6
The display will show 99 as the year. Using two digits, enter the year using the dial pad buttons (i.e. "05" for 2005).
Select NEXT, and repeat to change the month and the day.
Year: 99 Next Change Step 7
Once you have entered the day, press the RELEASE (RLS) key to end your session. This will save the changed time and date
87helpful
2answers
How to change time on my T7316E Nortel phone
Step 1
Once you have entered the day, press the RELEASE (RLS) key to end your session. This will save the changed time and date.
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
