A
Anonymous Posted on Aug 27, 2014
<!-- from fixya rte -->How to remove a paper jam? - Lanier Office Equipment & Supplies
2answers
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
3helpful
2answers
Paper is jammed in my HP Photosmart C3180 All-in-One. Can't figure out how to open machine to remove paper.
Follow these steps to clear the jam from the product. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray.
CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Remove any loose paper Do not pull jammed paper c01954290.gif c01961869.gif Step two: Clear the jam from the rear of the All-in-One Follow these steps to clear the paper jam from the rear of the product.
CAUTION: Never pull jammed paper from the front of the product. Pulling paper from inside the front cover can cause mechanical damage to the product. Always access and clear paper jams through the rear access door.
  1. With the product powered on, disconnect the power cord, USB cable, and Ethernet cable from the rear of the product.
  2. Press in the tab on the rear access door to release the door. Pull the door away from the product to remove it. Figure 1: Remove the rear access doorc00703963.gif
  3. To avoid tearing jammed paper, gently grab both edges of the jammed paper, and then pull with even pressure to remove.
  4. Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product.
    CAUTION: Make sure to remove any bits of torn paper from the rollers inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure 2: Check the product for bits of torn paperc01979299.gif
  5. While you have the rear access door removed, check the rollers with your fingers. Rollers should roll freely and feel springy. If rollers are missing or do not turn freely, buy a replacement rear access door. Click here to order a replacement part from HP .
  6. Reattach the rear access door. Gently push the door toward the product until it snaps into place.
Step three: Clear the jam from the front of the All-in-One
CAUTION: Carefully remove bits of torn or jammed paper from the front of the product. If you pull too hard on jammed paper, you might damage the print mechanism.
  1. Make sure that you disconnect the power cord from the rear of the product.
  2. Open the cartridge access door. Figure 3: Open the cartridge doorc00372271.gif
  3. Gently pull out any jammed bits or torn pieces of paper from the rollers inside the product.
    CAUTION: If the paper tears when you remove it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If pieces of paper remain in the product, more paper jams might occur.
  4. Close the cartridge access door.
  5. Reconnect the power cord to the rear of the product.
  6. Press the Power button (c01602202.gif ) to turn on the product.
4answers
Paper jam???
Follow these steps :
1.1
Remove all paper from the trays. This will prevent further jams during the clearing.
2.2
Remove the covering to the printer's outer case to expose the jam. Locate the jammed paper to ensure there is not another problem causing the stall.
3.3
Pull gently on the jammed paper, taking care not to tear it. In most cases, this will remove the jam.
4.4
Press the flashing "Printer Jam" button. This will allow the rotors to turn and facilitate the release of the jam.
5.5
Turn off the printer and firmly pull on the jammed paper. Be careful not to tear it.
6.6
Remove remaining paper shreds. if a tear occurs, remove any residual paper that may hamper printing.
7.7
Refill the paper tray and try printing again. If the jam persists, repeat the process and search for more paper.
1helpful
2answers
Had paper jammed - removed jammed paper - but nerror light still on
Before you can clear a "PAPER JAM" or "PRINTER JAM" error, you must locate where in the unit the paper is jammed.
First, unplug the machine for safety and disconnect the telephone line. Next, follow these instructions based on where the paper jam is located.
Paper is jammed inside the paper tray:
  1. Pull the paper tray out of the machine.
  1. Pull out the jammed paper to remove it.
  1. Reload the paper in the paper tray.
  2. Reinstall the paper tray.
Paper is jammed inside the machine:
  1. Remove the jam clear cover on the back of the unit. Pull the jammed paper out of the machine.
  1. Re-insert the jam clear cover.
  2. If you can not pull out the jammed paper, lift the scanner cover from the right-hand side of the machine until it locks securely into the open position.
  3. Remove the jammed paper.
  4. Check the print head's position. In the example photo the print head is positioned at the left hand side of the platen area.
  5. Gently move the print head to the center.
    Note Be careful to not force the print head to move.
    If the print head is positioned at the far right hand side, you cannot move it. Please contact Brother Customer Service from "Contact Us".
  6. Examine under the print head. If anything is found, remove it.
    Note Use a flashlight if necessary to check thoroughly.
  7. Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
  8. Reconnect the power cord and telephone line.
Note To prevent paper jams, do not put multiple kinds of paper in the paper tray at the same time.
If the message continues to appear on the LCD, the machine will require repair. Please contact Brother Customer Service from "Contact Us".
Thanks for using fixya......
1helpful
Paper jam how to repair
In case of paper jam, switch off your printer. Gently try to pull out the jammed paper. Dont force too much if in case the paper is jammed very hard.
There should be a paper jam removing window behind the printer. Locate it. Remove the back paper jam removing compartment and pull out the jammed paper from behind your printer.
I hope this solution is helpful to you
Thanks
4helpful
2answers
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
2answers
Paper jam error
Open the access door, move the carriage if necessary, and then remove any jammed paper. On some Laserjet printers, you might need to remove the toner cartridge and/or imaging drum to access the paper jam. If your printer has a paper path cover behind the carriage, remove the cover, and then remove any jammed paper
Regards,
Will
2answers
Paper jam in hp deskjet 5900 series. how do i correct?
 Follow these steps to remove a paper jam:
1. Press the Resume button.
  If the paper jam does not clear, then go to the next step.
2. Turn off the printer.
3. Remove the rear access door. Press the handle to the right, and then pull out the door.
4. Remove any paper that is inside the printer by pulling it out from the back of the printer.
  If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
5. Replace the rear access door securely.
6. If the paper jam cannot be removed from the back of the printer, raise the printer cover, remove the paper jam from the front of the printer, and then lower the cover. Caution Remove the paper jam carefully as it is possible to damage the
  printer when removing paper from the front.
7. Turn on the printer, and then press the Resume button.
8. Reprint the document. Note If paper jams occur frequently, try using a heavier paper. See the reference guide for paper weight specifications.
Top Lanier Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
