Hotpoint Aquarius WF220 Front Load Washer Logo
A
Anonymous Posted on Aug 27, 2014
Hotpoint aquaris wf220 door closes and all lights working but machine won't start ?
Machine won't start even though all lights working ,door seems not getting signal for machine to start
Jorgie Navito
Level 3:
Master:
  • Hotpoint Master 357 Answers
  • Posted on Feb 11, 2015
Jorgie Navito
Hotpoint Master
Level 3:
Master:
Answers
357
Questions
0
Helped
108787
Points
2245
CHECK UR DOOR SWITCH
5 Related Answers
BIGIFA
  • 27 Answers
  • Posted on Feb 22, 2008
SOURCE: HOTPOINT aquarious extra
whare the option buttons are if you number them 1 to 5 from top to bottom if led 2 and 4 are flaching this is a time out draining and you will need to check your waste hose for twists traps and kinks also check Filter if there is a user servicable one on the applionce and check plumbing. This is a comman fault and if you get hotpoint out to it even if it is only a day old they will charge for the call out as it is classed as user error or faulty instalation this works on all WF,WD & WT modles with 5 option buttons on the left habnd side the applionces with digital displays will show F-05 insted but it all means the same
Anonymous
  • 1294 Answers
  • Posted on Mar 17, 2008
SOURCE: hotpoint aquarious wf 210 washing machine
Look for the problem in manual:
http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jan 13, 2009
SOURCE: Hotpoint aquarious + flashing H 20 on display
H20 is indicating that you have no water coming in.
Check water is turned on,check hose(s) are not kinked, and finally check inlet valve.
If you are not sure if there is water to m/c, turn the tap off, disconnect the hose(s), and hold over sink and turn tap back on, water should come out, if it does not, then there is a prob with the supply.
Plz rate my solution.
Thanks.
Anonymous
  • 4 Answers
  • Posted on Jun 06, 2009
SOURCE: I've got a hotpoint wf220 wshing machine which is
i have a hotpoint wf321 water comes in and pumps out have flashing mini load light on and start light, but drum does not go round,
Anonymous
  • 86 Answers
  • Posted on Mar 06, 2010
SOURCE: Hotpoint Aquarious WF210. Machine stops mid
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For Hotpoint, Creda and Indesit error code definitions use this link. This will give you some idea as to where the fault may be.
The door seal has gone on my hotpoint aquarious 1000 machine & I can't open the door even though the spin cycle has finnished. Can anyone help please?
For most front-loaders:
Open the top of washer, screws behind, slide away from front couple of inches & lift up. Lubricate the slot which fits over the tub with washing-up fluid, if there is resistance to insert. Starting at the top, press the seal so the flange of the tub enters the slot on the seal. Work your way round the using thumbs to force the slot on the tub flange. When slot is on the flange all way round, fit the spring which holds it on. The spring goes into a slot on the outside of the seal. This is quite difficult and you may need another pair of hands. Fit the outside of the seal to the cabinet - this is easy and fit the plastic clamping ring.
Test for leaks before using. Use rinse to test as the water level is higher.
(There is no glue anywhere, only clamps,etc)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Pl rate me ‘very helpful’ for the free help!
Door light no working so machine will not start
check power is getting to machine with suitable electrical screw driver.to do this remove top from machine and check live wire just inside rear of machine. fault could be door lock if you have power in machine
3helpful
Aquarius washer drum stuck
sounds as if the drum bearings have gave way was it noisey b4 this
1helpful
Door on hotpoint aquarious wont open at end of wash cycle...in spite of door light OFF. Have checked drain off plug..its OK!
door catch is faulty unplug machine take off lid put hand down to door switch and pull back to open door replace handle kit
1helpful
Operating instructions
Hello.
I can help you with your query.
In your browser bar type in hotpoint user manuals
In the drop down list, click on
manuals-user guides-handbooks-hotpoint service
In the search box enter your model number and download the instructions.
Please rate my fixya solution.
Thankyou
Door lock
Switch off. Try some WD40 on the machine lock (not on door) and open & close door many times, to ease out the lock.
Wff220 will not start when door closed - lights up briefly
If you press and hold the door and the lights come on, then I syspect that the door catch or spring may be broken.
If it has a start/pause, try that.
Hope this helps.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
